Backpack and testing using a Prop Plug with PC
Hi Folks. Please be kind as I am a Prop Newbee
I have just brought a Propeller Backpack and a Prop Plug.
With these can I use a serial program on my Windows PC to test various commands firstly in Terminal mode, and secondly in Overlay mode. Or do I need to do some additional work re RS232 levels.
My target is to use the Backpack in Overlay mode and chatting to it using a FEZ Mini. I've also brought a NTSC camera so I don't have to do a PAL conversion since I am in Australia.
Many thanks for any advice you can provide..
Take Care
Dave
Take Care
Dave
You can certainly communicate with the Backpack via the PropPlug. Just set whichever serial I/O driver you choose to receive on pin A31 and to transmit on A30, using positive logic and the baud rate of your choosing.
I'm up Brisbane way. My main processor of choice for quick jobs is the PicAXE as I am a basic programmer from WAY back (started in computer in '74)
I use the PicAXE akin to the old 555 timers - except they are programmable.
About the largest PicAXE I had ever needed to use was a 28X2 and that was so I could make a I2C slave.
I've looked at Arduino's amd although they are nice they still don't have the processing power that I need.
Currently I am working on a high level project using a FEZ Mini. This is a 80Mhz processor that runs C# and the NET MicroFramework so I have a good highend language to use. Great for string manipulation and threading. Plus the Mini is in the same formfactor as a Basic Stamp 2
I got the Propeller Backpack solely for it's OSD capabilities so it's really a means to an end. I've looked at the MAX7456 but it does have som limitation re colors etc and you chat to it using SPI which again means more I/O to control things.
Not sure if Ill go down the path of learning the Propeller - I'll play around with the Backpack first and try a couple of things.
I've mentioned the project I am doing. I play around with Animatronics, Special Effects and Costume Making as a hobby. With costumes think of things like the Werewolves from Underworld where there is animatronics to control the facial features.
Now - to control something like that you generally need 4 helpers off to one side doing the remote control work and the actor moving the suit around. Really not good if want to go out on your own.
So.. I have been designing a low cost system where preset emotions can be programmed onto an SD card and then play whenever the actor wants to do something like smile, snarl, look interested etc.
I hope I can put this system out for about $150 sans's servos.
With the current costume it's very difficult to see out of it so I am using a head's up display made from iPod video glasses and small vid camera's. This gives me sterioscopic vision. As an added bonus I can also display using the Prop Backpack critical information about the costume like wearer's body temp, battery life, currently running commands and a few more.
Anyway - look forward to hearing from you
Dave a.k.a. Marcwolf
