Backpack and testing using a Prop Plug with PC — Parallax Forums
marcwolfmarcwolf Posts: 38
edited 2011-01-08 01:32 in Propeller 1
Hi Folks. Please be kind as I am a Prop Newbee
I have just brought a Propeller Backpack and a Prop Plug.
With these can I use a serial program on my Windows PC to test various commands firstly in Terminal mode, and secondly in Overlay mode. Or do I need to do some additional work re RS232 levels.
My target is to use the Backpack in Overlay mode and chatting to it using a FEZ Mini. I've also brought a NTSC camera so I don't have to do a PAL conversion since I am in Australia.
Many thanks for any advice you can provide..
Take Care
Dave
    edited 2011-01-06 22:20
    Dave,
    You can certainly communicate with the Backpack via the PropPlug. Just set whichever serial I/O driver you choose to receive on pin A31 and to transmit on A30, using positive logic and the baud rate of your choosing.
    edited 2011-01-07 13:15
    marcwolf: Dave, welcome to the prop forum. This is a great forum and you will get lots of help here even if you are an Ozzie. BTW so am I :) Where in Oz are you?
  • marcwolfmarcwolf Posts: 38
    edited 2011-01-07 15:26
    Hi Cluso99
    I'm up Brisbane way. My main processor of choice for quick jobs is the PicAXE as I am a basic programmer from WAY back (started in computer in '74)
    I use the PicAXE akin to the old 555 timers - except they are programmable.
    About the largest PicAXE I had ever needed to use was a 28X2 and that was so I could make a I2C slave.
    I've looked at Arduino's amd although they are nice they still don't have the processing power that I need.
    Currently I am working on a high level project using a FEZ Mini. This is a 80Mhz processor that runs C# and the NET MicroFramework so I have a good highend language to use. Great for string manipulation and threading. Plus the Mini is in the same formfactor as a Basic Stamp 2
    I got the Propeller Backpack solely for it's OSD capabilities so it's really a means to an end. I've looked at the MAX7456 but it does have som limitation re colors etc and you chat to it using SPI which again means more I/O to control things.
    Not sure if Ill go down the path of learning the Propeller - I'll play around with the Backpack first and try a couple of things.
    I've mentioned the project I am doing. I play around with Animatronics, Special Effects and Costume Making as a hobby. With costumes think of things like the Werewolves from Underworld where there is animatronics to control the facial features.
    Now - to control something like that you generally need 4 helpers off to one side doing the remote control work and the actor moving the suit around. Really not good if want to go out on your own.
    So.. I have been designing a low cost system where preset emotions can be programmed onto an SD card and then play whenever the actor wants to do something like smile, snarl, look interested etc.
    I hope I can put this system out for about $150 sans's servos.
    With the current costume it's very difficult to see out of it so I am using a head's up display made from iPod video glasses and small vid camera's. This gives me sterioscopic vision. As an added bonus I can also display using the Prop Backpack critical information about the costume like wearer's body temp, battery life, currently running commands and a few more.
    Anyway - look forward to hearing from you
    Dave a.k.a. Marcwolf
  • Cole LoganCole Logan Posts: 196
    edited 2011-01-07 16:00
    Sounds like a vary interesting project. Can you keep us updated on your progress and truthfully it sounds like to me you could probably do this all with a propeller. :-)
    This sounds very interesting and different to the normal projects (if any are normal) :) Do keep us updated. I started in mini-computers in '74 on Singer System Tens (later ICL) and in micros in '76 interfacing them to the System Ten. I have written a validated ICL System 25 on a 486 so one day when time permits I would like to program a prop to emulate the S25.
