I need a Spin counter expert to examine some code for me PLEASE :) - Page 5 — Parallax Forums
1235
  • idbruceidbruce Posts: 6,197
    edited 2011-01-07 13:02
    Jon
    Here are the files to prove it.
    Bruce
    edited 2011-01-07 13:06
    Jon
    I will take another look at you example and see if I can get it to work for me.
    Bruce
    edited 2011-01-07 14:36
    Jon
    {jm_step_pulser_wip_v2b) That is awesome!
    Bruce
  • bsnutbsnut Posts: 521
    edited 2011-01-07 18:32
    Bruce,
    I know you are trying to do a driver for stepper motor to control timing with the propeller. I have this simple idea for you and that is. Use a stepper motor IC and only uses little as two pins and no more than four pins to control it.
    This idea was in a book, I have on PIC projects and its by John Iovine. The whole goal is to save pins for other uses.
    edited 2011-01-07 19:00
    bsnut
    Unless the IC has some magical way to translate a number of steps and the direction you want, you will still have to provide at least two types of pulses for the motor to move. Stepper driver ICs are nothing new to me, it all depends on how your motor is wired. If it is wired in unipolar fashion, you can just use transistors or fets and send pulses to the motor to rotate it. If it is wired bipolar, you need some type of h-bridge. That being considered, you can buy a stepper translator IC which will translate direction and an oscillator to make the motor rotate in the direction you want. Then you have all in one ICs that include the h-bridge and the translator or mosfets and a translator. Driving a stepper motor is no major issue, but driving one to its full potential is quite a different thing. The drivers I have require two inputs, which are direction and step. The step pulse is what this thread is all about. If you cannot provide a proper waveform to the translator, you will never get your motor to run properly.
    When I say "Driving a stepper motor is no major issue", that is an understatement. There are many things that have to be considered to make it run well. And this thread is just covering one of the issues.
    Bruce
    edited 2011-01-08 09:11
    Bruce, how big a step can the motor take at once? For example, from 1 kHz, can it immediately step up to 1.1 kHz, say, or 2 kHz possibly? I know you gave an maximum acceleration rate as suggested by the manufacturer, and the focus of your interesting effort has been to build the pulse rate gradually to get the best performance without violating the rate rules.
    Just in the interest of doing things in a different way, I took my burst generator method and put it in a loop. The output frequencies and the count of pulses at each frequency come from a table.
    myHertz := lookup(idx:1000,2000,3000,4000,5000,6000,7000,8000,9000,10000,9000,8000,7000,6000,5000,4000,3000,2000,1000,0)
    myBurstN := lookup(idx:100,200,300,400,500,600,700,800,900,11000,900,800,700,600,500,400,300,200,100,0)
    The process builds in 1000Hz steps at 100ms per step, up to 10 kHz where it dwells for 11000 cycles, and then back down to zero. The number of pulses add up to 20000. The code queues up the next burst while the previous one is being produced by the counters. The transition from one burst to the next takes about 20µs, so there is a little timing glitch there as a proportion of the one cycle at the transition. The maximum pulse frequency in Spin is about 25 kHz.
    Thus my question about steps as opposed to a smooth transition.
    edited 2011-01-08 09:20
    Tracy
    I will examine the code, however, this morning I took all the knowledge I gained this last and created a new driver which does 13.34 revs per second with an accurate step count, and it is written in Spin. In fact, I just posted it to the Propeller forum when I got the message that you posted here. As you can clearly see, I am looking for ways to improve speed and accuracy, and I am always open to new suggestions and ideas. So thank you very much for you sample. I don't know if I will understand it, but I will definitely take a look. Thank you so much.
    Bruce
    edited 2011-01-08 09:21
    Tracy sorry I missed some of that, I will respond more in a sec
    edited 2011-01-08 09:37
    Tracy
    To be perfectly honest, I don't know the answers to your questions. I am still struggling to get a good grasp on Hertz cycles and the system clock. For the most part, I have just been hacking my way through it without the proper knowledge. I got lucky this morning. You may want to look at the code I posted to the forum, because it will give you a general idea of what works well. But as mentioned in that post, I know the motors can go faster, as I learned from JonnyMac's sample PASM code. Additonally, within this thread, there is an attachment entitled G251 Manual. That manual provides the mavimum specs and answers to your question, because ultimately, I cannot provide a pulse faster than that drive can handle. But there are also other issues to consider, such as the moments of inertia for the motor, and any mechanical assembly attached to it.
    Bruce
  • MagIO2MagIO2 Posts: 2,243
    edited 2011-01-08 09:40
    Hi Bruce,
    just fiddled around with Jonnys code. Just want to post my results here. It shows how an object could look like. As Jonnys code is counting steps accurately it's easy to do accurate stepping. But still I think best way would be to do the whole rampup and rampdown in the PASM part. Thist would be the next thing I'd want to change. And I think Tracy's way would be very good to do that.
    StepperTest.spin
    CON
      _clkmode = xtal1 + pll16x                  ' System clock → 80 MHz
      _xinfreq = 5_000_000
    OBJ
      stepper1: "Stepper"
    PUB main
      ' start the stepper driver
      stepper1.start( 10, CLKFREQ / 500_000, 2_000, 20_000 )
      repeat
        stepper1.RUpStepRDown( 4_000, 4_000, 100)
        waitcnt( clkfreq*5+cnt )
    Stepper object (Stepper.spin)
    VAR
      long nCounterTime, nCounterDelta
      long curPulseWidth, minPulseWidth, stepcnt
      long maxSpeed, minSpeed
      long stack[10]
      byte theCogID
    PUB start( pin, minPW, maxSp, minSp )
      if theCogID
        cogstop( theCogID - 1 )
      ' store the parameters for later use
      if minPW<0
        minPulseWidth := minPW
      else
        minPulseWidth := -minPW
      maxSpeed := maxSp
      minSpeed := minSp
      ' initialize the parameters for the stepper COG
      curPulseWidth := 0
      nCounterDelta := minSp
      nCounterTime := 0
      ' start the stepper COG
      theCogID := cognew( stepper( pin ), @stack ) + 1
      ' wait until the COG is up and running
      repeat until nCounterTime
      return theCogID
    PUB RUpStepRDown( upS, downS, steps)
      ' synchronize with the stepper COG
      repeat until (nCounterTime-cnt)>1_000
        waitcnt( 400 )
      waitcnt(nCounterTime)
      ' start the stepper pulse
      curPulseWidth := minPulseWidth
      ' ramp up
      repeat nCounterDelta from minSpeed to maxSpeed
        waitcnt( upS + cnt )
      waitcnt( clkfreq + cnt )
      ' ramp down
      repeat nCounterDelta from maxSpeed to minSpeed
        waitcnt( downS + cnt  )
      ' switch off pulse
      curPulseWidth := 0
    PUB stepper( pinNo )
      CTRA[30..26] := %00100 ' Configure Counter A to NCO
      CTRA[5..0] := pinNo
      FRQA := 1
      DIRA[pinNo]~~
      ' chance is there that nCounterTime is zero, but then it will be different after the
      ' first loop and the start method would return then
      nCounterTime := CNT + nCounterDelta
      ' keep this loop short to allow max speed
      repeat
        PHSA := curPulseWidth
        stepcnt++
        WAITCNT(nCounterTime += nCounterDelta)
    [/code]
    edited 2011-01-08 09:43
    PS: Bruce, does your project only drive on stepper or do you drive more than one axe? What about synchronizing then? Do you need to move in circles then?
  • JonnyMacJonnyMac Posts: 9,820
    edited 2011-01-08 09:55
    You're probably making it harder than it is. There is a system variable called clkfreq which is expressed in Hz (cnt ticks per second). When you want to run a signal at a specific frequency you simply divide the target frequency (in Hertz) into clkfreq; this will give you the number of ticks in the period that corresponds to that frequency.
    As I indicated before I think this is good practice as it makes your code independent of the PLL setting.
    edited 2011-01-08 09:57
    MagIO2
    The bending machine has 8 steppers, as far as I can guess at the moment before updating my inline code, 3 or 4 steppers will be the maximum number of steppers that will be running at one time. There are no major issues of collision, the main issue is the position of the bending head when all these movements take place.
    Concerning the packaging machine, it only has 3 steppers, and there is only one situation where two steppers must operate at the same time, and there is no major concern for collision, only timing.
    I don't know what mean by that question.
    Bruce
    edited 2011-01-08 09:59
    MagIO2
    PS The packaging machine and the bending machine each have their own propeller.
    Bruce
    edited 2011-01-08 10:05
    Jon
    LOL I just posted some code in the forum and I forgot all about that. I will have to update that code. Thanks for reminding me and thanks for tips concerning the hz and clock. I will have to spend some time and study that later, because my head is swimming at the moment. I tested your code yesterday and it worked well, those motors were flying. But I was having some trouble with accurate step count. Perhaps I was going tooooo ffaaaastttt :)
    Bruce
    edited 2011-01-08 10:11
    Maybe -- the PASM code I wrote doesn't have any trouble with the steps, but a foreground Spin program may not be able to keep up in some cases.
    I noticed. It's generally not a great idea to start multiple threads on the same topic -- makes it hard for folks to follow, especially when you seem to be so far from a committed design that is flexible enough for general use.
    edited 2011-01-08 10:37
    Here is some code which uses Jonnys driver to ramp up, step and ramp down. It's idea is to use 10 steps (= 1 full step) with one speed setting.
      repeat
        pulsehi := US_001 * 2                                     ' set output pulse width
        repeat freq from 40_000 to 2_000 step 50
          steps := 10                                                ' output 3 steps
          repeat while (steps > 0)                                  ' let them finish
        ' delay for scope retrigger
        steps := 50_000
        repeat freq from 2_000 to 40_000 step 50
    If I'd only have one of these stepper boards and a stepper ... it would be much more exciting to see something move compared to watch a scope ;o)
    edited 2011-01-08 10:46
    Jon
    It was not my intention to suggest that there was a problem with your code. I should have clarified myself a little better.
    Bruce
    edited 2011-01-08 10:51
    MagIO2
    Could you please explain this to me?
    if theCogID
    Bruce
    edited 2011-01-08 11:01
    Tracy
    At the top of your code it says that it is for 20,000 steps, however I only found a loop for 20, is the value 20 broken down somehow to create 20,000?
    For valid testing, I need a decent step count, perhaps 1,000,000.
    Bruce
    edited 2011-01-08 11:14
    if theCogID
    only makes sense with the respective COGNEW:
    theCogID := COGNEW( @stepper, 0 ) + 1
    COGNEW returns -1 in case no more COG is available. With the +1 it means, whenever no more COG can be started you'll find 0 in theCogID. The stop-function should also set theCogID to zero if it exists. In other words, whenever you find a number > 0 a COG is already running the driver. So, if you call the function start twice (for the same object), the already running COG should be stopped.
    The if uses the fact that 0 is the same as false and ANYTHING else is the same as true.
    Because we added 1 to the real COGID we have to subtract 1 in case we do the COGSTOP.
    edited 2011-01-08 11:16
    MagIO2
    Thank you for explain that.
    Bruce
    edited 2011-01-08 11:25
    Bruce,
    The program executes a sequence of steps described by this syntax:
    When you add up the step count:
    100+200+...+900+11000+900+...+200+100 = 20000
    The program steps the index, idx, through the lookup table that has 20 entries, but the total number of pulse steps is the 20000 in the myBurstN summation. This is an ad-hoc example. It could be done by mathematical computation or by alternative types of table lookup. In any case, you
    have to determine the total number of steps and parse it out into a series
    of discrete steps.
    edited 2011-01-08 12:07
    Bruce,
    I think you misunderstood MagIO2's question about synchronizing multiple motors. He wasn't referring to collisions, but to coordinated motion, wherein more than one motor has to track the actions of another, perhaps starting and stopping at the same time, but after different numbers of steps. There are several methods used to attain this, including linear, spline, and circular interpolation -- hence the term "circles" in his question.
    edited 2011-01-08 12:25
    Hello Phil
    Thanks for pointing that out to me. In my situation, none of the motors have to be syncronized. However, I will have to track when there movement is complete. E.G.... Motor #5 will not be allowed to move until Motors #2, #3, and #4, return a value indicating there job is done.
    Bruce
    edited 2011-01-08 12:38
    @MagIO2
    http://www.watterott.com/index.php?xb1771=hsn00spimmmbqll2rdh188v6p4&page=search&page_action=query&desc=on&sdesc=on&keywords=schrittmotor&x=0&y=0
    I asked the company.
    The steppermotor should be available again next week.
    best regards
    Stefan
    edited 2011-01-08 15:09
    Hello Everyone
    As a direct result of this thread, up to this point, my production capabilties have increased by 150%. I just tested. Thanks everyone.
    Bruce
    edited 2011-01-08 18:35
    Bruce,
    I know you have made a decision on this subject.
    The stepper motor IC that I am talking about is UCN5804 can handle unipolar stepper motors up to 35vdc @1250mA and it has inputs for the following
    1. Output Enable
    2. Direction
    3. Step Input
    4. Half Step
    5. One-Phase
    This site should give you more info on UCN 5804 and a schematic on how it's connected.
    www.imagesco.com/articles/picstepper/06.html
    edited 2011-01-08 18:36
    Bruce,
    1. Output Enable
    2. Direction
    3. Step Input
    4. Half Step
    5. One-Phase
    edited 2011-01-08 19:00
    bsnut
    I appreciate your input, but that chip won't come anywhere near powering my stepper motors. I have a 50VDC power supply, and my motors need 2.83A per phase. And besides, I already have my drivers. My motors run good now thanks to this thread and the people like you that responded.
    Bruce
