Need help with Prop. Video Generator Unit (VGU)
Hi Folks,
New Prop user here, scored a Prop. Professional Dev. board for x-mass. Have tried a few programs and all works very slick. I started playing around with the Video Generator/serializer, and have a few questions about its operation (timing actually). I understand that before using it you must:
1) configure the video pins you want to use as outputs
2) configure the VCFC register
3) configure the VSCL reister
4) configure PLLA (which is the independent clk. source for the VGU)
I have done all this, loaded the WaitVid instruction with dummy data to toggle output (colors = $FF_FF_FF_00, pixels= $55_55_55_55) and looked (with O'scope) see if the output pins were toggling at my (expected) predetermined rate.
Well, it is toggling, and does change frequency when I change parameters, but not at the rate I expect. I set VCFC = 2-color mode; VSCL = 1 clk/pixel, 32clk/frame; FRQA = 80Mhz; and CTRA = video mode, VCO/4. From this I would expect to see a square wave output from any of the video output pins at 80Mhz/4 = 20Mhz but instead see a squarewave at ~3Mhz.
Can anyone shed any light on this? Code attached below.
thnx, -h
thnx, -h
DAT
org 0
LCDgen mov dira, outPins 'make outputs
movi vcfg, #%0_01_0_0_0_000 'VCFG set to 8-bit, 2-color).
movd vcfg, #%000000_000 'pins 7..0 for video output
movs vcfg, #%0_0101_0111 'mask to be used for video output -
mov VSCLset, _VSCLset
mov vscl, VSCLset 'mov timing of video output to vscl register
mov FREQa, _FREQa
mov frqa, FREQa 'set frequency of CTRA
movi ctra, #%000001_101 'start counterA in video mode
mov pixels, _pixels '
mov colors, _colors
:loop waitvid colors, pixels
jmp #:loop
_pixels long %0101_0101_0101_0101_0101_0101_0101_0101 '0,1,0,1,0,1 etc
_colors long %1111_1111_1111_1111_1111_1111_0000_0000 ' 0=0's, 1=1's
outpins long %0000_1000_0000_0000_0000_0000_1111_1111
_VSCLset long %0000_0001_____0000_0010_0000 '
_FREQa long 80_000_000
pixels res 1
colors res 1
VSCLset res 1
FREQa res 1
Also, how did you calculate the frequency? You need to put in a value that when accumulated at speed = equals your desired frequency.
Try (desired_frequency / clockspeed) << 32
Basically, the counter will be incrementing each clock cycle. You want the period of those increments to roll over the 32 bit counter register at your desired frequency.
The more ones you have in that value, the more "jitter" you will have in the output. It's not a bad idea to round to closest value, keeping the number of "1" digits to a minimum, because of that.
Also, the PLLDIV of /4 will give you a pixel clock of 20MHz and therefore a 10MHz square wave.
So I added to my code, and am now also activating the second counter (CTRb) as a NCO single-ended, using the same timing parameters as the VGU. I put in $1000_0000 for both FRQa/b, and the output from CTRb (pin0) is as expected, 5MHz (per the formula PHS[31] freq. = clkfreq*FRQregister/2^32)
However, the output from the VGU is (with divider set to 1/4) 10MHz as Eric says. I would have expected 5MHz/4 =1.25MHz. I know I am being somewhat obtuse here, but what am I missing? New code (adding CTRb) shown below.
Thanks again,
-h
DAT org 0 LCDgen mov dira, outPins 'make outputs movi vcfg, #%0_01_0_0_0_000 'VCFG set to 8-bit, 2-color). movd vcfg, #%000000_000 'pins 7..0 for video output movs vcfg, #%0_0101_0010 'mask to be used for video output - mov VSCLset, _VSCLset mov vscl, VSCLset 'mov timing of video output to vscl register mov FREQa, _FREQa mov frqa, FREQa 'set frequency of CTRA movi ctra, #%000001_101 'config counterA in video mode-divisor of ...4 mov FREQb, _FREQb mov frqb, FREQb 'set frequency of CTRb movs ctrb, 0_0000_0001 'set output pin from ctrb - p0 movi ctrb, #%00100_111 'config CTRb NCO-single ended, div of 1 mov pixels, _pixels ' mov colors, _colors :loop waitvid colors, pixels jmp #:loop _pixels long %0101_0101_0101_0101_0101_0101_0101_0101 '0,1,0,1,0,1 etc _colors long %1111_1111_1111_1111_1111_1111_0000_0000 ' 0=0's, 1=1's outpins long %0000_1000_0000_0000_0000_0000_1111_1111 ' _VSCLset long %0000_0001_____0000_0010_0000 ' _FREQa long $1000_0000 _FREQb long $1000_0000 pixels res 1 colors res 1 VSCLset res 1 FREQa res 1 FREQb res 1The PLL takes the output of PHS[31] then multiplies this frequency by 16 which is then divided down by PLLDIV. This is all explained in "PLL modes of operation" in Application Note 001 Propeller Counters. The place which I usually get confused in with PLLDIV. Just remember the divide is to the VCO output which is 16x the input frequency (which must be between 4 & 8 MHz). So the output frequency is 16x - 1/8 the input frequency.
Thanks for your help and pointing me in the right direction.
-h
