Open Source or Not! Heater, Ross, Mike G., Bean, Hippy
I'm adding open source information to software descriptions. What better way to know if code is open source or not, than from the original authors. I have collected and grouped the software titles below along with the authors. If the authors can post to this thread and tell us if the code is open source or not, it would be appreciated. (If different open source from the MIT License, please state the details) Thank you sincerely.
MITS ALTAIR 4K BASIC by HEATER
http://forums.parallax.com/forums/default.aspx?f=25&m=320075]forums.parallax.com/forums/default.aspx?f=25&m=320075
ALTAIR MINOL TINY BASIC, by heater
www.archive.org/web/web.php
http://forums.parallax.com/forums/default.aspx?f=25&p=1&m=320075
PROPTINY - Jack Crenshaw's TINY language by HEATER http://forums.parallax.com/forums/default.aspx?f=25&m=355121]http://forums.parallax.com/forums/default.aspx?f=25&m=355121
MOCOG V0.60 (6809 VARIANT) by HEATER
http://forums.parallax.com/forums/default.aspx?f=25&m=355169
MOTOROLA 6809 MOCOG by HEATER
http://forums.parallax.com/forums/default.aspx?f=25&m=355169&p=1&ord=a]http://forums.parallax.com/forums/default.aspx?f=25&m=355169&p=1&ord=a
The ZPU version of GCC for use with ZOG by heater
http://www.opensource.zylin.com/zpudownload.html
C++ by Heater
http://forums.parallax.com/showthread.php?p=919172
DUMBO BASIC by ROSSH Compiles under Catalina. There is also a DOS executable (the DOS version requires MinGW and GCC to compile).
http://forums.parallax.com/forums/default.aspx?f=25&p=3&m=388930
LISP - for HYDRA, written in C. Takes 96K., by ROSSH
http://forums.parallax.com/forums/default.aspx?f=25&p=1&m=353721]http://forums.parallax.com/forums/default.aspx?f=25&p=1&m=353721
http://forums.parallax.com/forums/attach.aspx?a=31586]http://forums.parallax.com/forums/attach.aspx?a=31586
BYWATER BASIC by ROSSH
http://forums.parallax.com/forums/default.aspx?f=25&m=388930&g=388936#m388936
http://sourceforge.net/projects/bwbasic/]http://sourceforge.net/projects/bwbasic/
JZIP by ROSSH http://forums.parallax.com/forums/default.aspx?f=25&m=388930&g=388936#m388936
PASCAL P4 COMPILER INTERPRETER USING CATALINA C BY ROSSH
http://forums.parallax.com/forums/default.aspx?f=25&m=388930&p=2]http://forums.parallax.com/forums/default.aspx?f=25&m=388930&p=2
http://propeller.wikispaces.com/Programming+in+Pascal]http://propeller.wikispaces.com/Programming+in+Pascal
ISO standard P5 Pascal compiler/interpreter by Ross
http://www.standardpascal.org/p5.html
Lua scripting language by Ross
http://www.lua.org/
META2 COMPILER by MIKE GREEN
http://forums.parallax.com/forums/default.aspx?f=25&m=233272
SPHINX SPIN COMPILER by MIKE GREEN
http://forums.parallax.com/forums/default.aspx?f=25&m=363645]http://forums.parallax.com/forums/default.aspx?f=25&m=363645
http://www.sphinxcompiler.com/]http://www.sphinxcompiler.com/ web site by mpark
OUROBOROS by MICHAEL GREEN
http://forums.parallax.com/forums/default.aspx?f=25&m=349616&p=2
OUROBOROS1 by MICHAEL GREEN
http://forums.parallax.com/forums/default.aspx?f=25&m=349616&p=2]http://forums.parallax.com/forums/default.aspx?f=25&m=349616&p=2
PROPBASIC by BEAN/HITT CONSULTING
http://forums.parallax.com/forums/default.aspx?f=25&m=380174]http://forums.parallax.com/forums/default.aspx?f=25&m=380174
http://forums.parallax.com/forums/default.aspx?f=25&m=381278
Embedded Basic Interpreter - a version of femtoBASIC in PropBasic by Bean http://forums.parallax.com/showthread.php?p=943563#post943563
http://forums.parallax.com/showthread.php?p=919764
Basic Stamp Emulator on a Prop by Bean
http://forums.parallax.com/showthread.php?t=111473&page=2
THUMB by HIPPY
http://forums.parallax.com/forums/default.aspx?f=25&m=235152 http://forums.parallaxinc.com/forums/attach.aspx?a=19014
PASCAL by HIPPY - The P4 compiler is open-source so can be modified
and tailored to make it more Propeller Chip friendly and useful. It's not
a complete Standard / ISO 7185 Pascal but a reasonable implementation.
http://forums.parallax.com/forums/default.aspx?f=25&m=246603]http://forums.parallax.com/forums/default.aspx?f=25&m=246603
PROPBS1 Basic Stamp Propeller by HIPPY
http://forums.parallax.com/forums/default.aspx?f=25&m=296149
http://forums.parallax.com/forums/default.aspx?f=25&m=220212
C++ by Heater
http://www.lua.org/
THUMB by HIPPY
And btw, I wrote Sphinx. Don't blame Mike Green.
ALTAIR MINOL TINY BASIC - No idea where it comes from. Assume closed source.
PROPTINY - By Heater. No license terms specified, perhaps one day I will put MIT terms on it in the unlikely event that anyone is interested.
MOCOG - By Heater. No license terms specified. Perhaps one day I will put MIT terms on it if anyone is interested.
What?
The ZOG byte code interpreter has no licence terms specified. I will put under M.I.T. at some point.
ZPU-GCC is under the GNU General Public Licence therefore open source.
C++
What?
I have managed to run C++ under ZOG and it is possible for MOCOG 6809, they are both GCC. See above.
Please take anything of mine which you find, here or elsewhere, as MIT Licensed unless it explicitly says otherwise.
Dumbo Basic is public domain. I will make this explicit in the next release.
I can't find any license terms for the lisp interpeter - but since it is freely available (here) from the auther without any license conditions specified, I would assume it to be public domain.
Bywater Basic is GPL
JZIP has its own licence terms (see the file license.c) but this appears to be MIT compatible.
Pascal (P4 & P5) is public domain.
Lua is MIT
