Serial Cable help to test reading stamp SEROUT
Greetings,
I am new to working with the BASIC Stamp II. I am using an old BSII with a carrier (2 - I think) board. I have no problems sending BS2 code to the stamp using the carrier board through a standard DB9 serial extension cable. I have been able to make LEDs blink as I learn about the stamp.
What I would like to do is to send output from the stamp to my computer's serial port. I have a simple BS2 program that sends stuff to PIN 16 using the SEROUT command. Also, I have a VB .net app (VS 2010) that allows me to select a com port and read any input from it.
Here is the question:
HOW DO I WIRE UP A SERIAL CABLE (DB9) TO THE STAMP WITHOUT USING THE CARRIER BOARD? ...like a real-world application if I were to measure temperature and log it every hour on my PC for example.
By placing the stamp on a breadboard with the program already downloaded to it:
- Do I supply power (+) to the chip using PIN 24 - VIN?
- Which PIN gets the (-) VSS??
- Can I use a regulated 12v power supply?
I tried wiring up a DB9 connector as follows:
DB1 - not used
DB2 -> SOUT
DB3 -> SIN
DB4 -> Not sure if I need to use this...?
DB 5 -> VSS
DB6 tied to DB7 with a jumper
DB8 - not used
DB9 - not used
Would this work?
Thanks in advance for any help,
Ron
01/03/2011
DB1 - not used
DB2 -> SOUT
DB3 -> SIN
DB 5 -> VSS
DB8 - not used
DB9 - not used
Would this work?
Ron
01/03/2011
Very nice development environment that you constructed! I may try something like that in the future.
From the pictures I still can not figure out the proper DB9 pins to stamp pin connections. --sorry!
I think I figured out how to power the stamp properly without using the Carrier board?
So, if I download a program to my stamp (using the carrier board) and then remove the stamp from the carrier board and put it on my breadboard and power up the stamp; I should theorectically be able to read SEROUT commands from the stamp to my VB program if I get a cable properly wired?
Lets assume that I am going to use PIN 16 in the SEROUT command... If so, how would I wire into a DB9 connector mounted to my breadboard? The other end would of course go to the PC (straight through cable).
DB1 - not used
DB2 -> SOUT
DB3 -> SIN (or Wire to PIN 16?)
DB4 -> Wire to PIN 16?
DB 5 -> VSS
DB8 - not used
DB9 - not used
Thank you again for any help in advance (or anyone else who can help me).
Cheers,
Ron
Immerse yourself in SEROUT/SERIN, DEBUG/DEBUGIN.
