Eight Pin Socket for SHT11
Bill Chennault
All--
I am transferring a BOE breadboard project to PCB. I think I may have over-heated my SHT11 during soldering. (Or, in my inexperience, simply wired the circuit wrong.) I should have socketed it. The sockets I bought for it (Jameco) were 8 pin IC sockets, which I now know are incorrect.
Will you tell me what to buy?
Thanks and Happy New Year!
--Bill
--Bill
This is what I bought: Jameco 94474. The pin spacing is right, but the holes don't seem large enough. (Do I just need to PUSH harder?)
This is my SHT11 (Sensirion Temperature/Humidity Sensor ) from Parallax.
Pardon my ignorance. Everything I've done has been breadboarded.
--Bill
This is exactly why I had to replace the socket on my BOE. In haste for a project, I crammed a ZIF socket into the BOE's socket. Worked fine while in there, but once the ZIF socket was pulled out, my BS2 module did not make a firm seat and did not work properly.
ps. I doubt you damaged the SHT11 by soldering. They are actually pretty durable and since it is on the module PCB as well, it would be pretty difficult to get that much heat to the module itself.
