EEPROM(CAT24WC128J) Problem! Help needed
Hello Everyone
I have made a Propeller USB Board by myself. And I choosed the chip CAT24WC128J as EEPROM on my board. But When I connect my board to the computer, there is problem to download the program to the EEPROM. By the way, the program could download to the RAM and then run. Has anyone here encountered this problem? How to solve it?
Here is the part of my borad's schematic about connecting between CAT24WC128J and P8X32A-Q44.
Thanks to all for the help and sorry for my poor english...
spacemanren
spacemanren
You EEProm are to small ---> 16384 words of 8 bits each. Propeller need dual so much
Hi Sapieha,
Thank you for your suggestion. Did you mean that if I change the EEPROM chip CAT24WC128J there will be no problem? Maybe AT24C512B?
Change to AT24C256 else AT24C512 --- That give Propeller space in it that it needs (32KBytes).
In 512 You can use upper half to other things.
