looking for a IP camera or webcam for robot
Hello all,
I want to build a robot that I can control over the internet with using a web camera
Any idea what is the best wireless webcam to use?
Is IP webcam a right selection or something better available to use?
Also I want to Cam to be battery operated.
If possible, can you give me the name and brand of Webcam that you have experience with and you think is a good fit?
Borna
Borna
a netbook and a 3G card can do the same thing . and work allmost anywhere .
Peter KG6LSE
To get things setup, all I did was "View Source" in the browser while viewing the camera stream. Then I could see the API files that made the camera work. So I simply downloaded the source from the camera's hardware and dropped them on my web server. Next I configured my internal network to direct external video requests to the camera. Finally, I create a service to handle robot commands over Zigbee wireless.
There are some IP camera's that have servos. You can hack the servo connection to make a basic messaging system. Shot the pulse width modulation (PWM) used to control the servos to a microcontroller.
Both robots have been on woot.com within the past year for $99, FYI. Hard to say no to prices like that !
