Prop Vessel Monitoring System (PropVMS) — Parallax Forums
Kevin BrownKevin Brown Posts: 44
edited 2010-12-29 12:37 in Propeller 1
Llike many boaters I have to keep my boat some distance from my home. Reading through the forums there seems to be several people interested in projects like this so I thought I would make mine available.
It is a work in progress in many of the planned features are not working yet. I'm using a propeller demo board and the Spark fun GM 862 – GPS breakout module .The code is based on bits and pieces that I pulled out of programming and customizing the multicore propeller book which I found extremely useful. Currently the system has three inputs, one for a float switch for high water alarm, one for a window comparator for battery voltage alarm and one for door and hatch switches. The system is currently set up to place a phone call and send an SMS message indicating the alarm condition. One thing about SMS messages there is no quality of service requirements for them so it can be several minutes or hours before they're delivered to the recipient so the device will also place a call to whatever number you want so you will get a call and an SMS message following to let you know the condition. Because of an error on the GSM breakout board the GPS antenna does not fit so the GPS data has not been integrated into the system yet.
The system will also have an Xbee and Bluetooth interface. I plan to use the Xbee to control remote relays for bilge pumps, lights and eventually the ability to remotely control and monitor the HVAC systems and environmental conditions temperature/humidity via SMS messages. The Bluetooth will be used for local control via a smart phone.
I thought about using one of my ham radios HT's and could easily made the hop between my boat and home but I'm not always home and I don't always have my handy talkie (HT) with me, But my cell phone is always with me
PropVMS.spin
    edited 2010-12-18 17:20
    Kevin: Thanks for your info. I now have aTelit GE864-Quad GRS with AT command set. Initially I will send an SMS. Later I will make a phone call where I can say "hey you, get off my boat".
    I have an IR sensor which I bought for ~$30. It has batteries and a keypad all in one. I plan to hack this. Obviously it will take me some time - other things on but I want to ultimately include video or still pics so I can see what is happening if necessary. I think the mobile network is the best (via internet) because I always have my mobile phone with me.
  • Kevin BrownKevin Brown Posts: 44
    edited 2010-12-19 11:09
    Yes video would be nice I have an IR camera that I want to add also....... waiting for the 4G modules then I will be able to stream live video
    edited 2010-12-19 14:52
    We have 4G mobiles (called NextG in Australia). I have a USB dongle version which is just for data. They say it will go to 21Mbps but I only get a few Mbps which is fine for Skype etc. There is a standalone version which has WiFi for connecting to a few laptops which I am sure could be connected to the WiFi cameras. Of course, this requires a more expensive service.
    Perhaps the ZipIt2 could come in handy here too because it has WiFi and a serial port (needs to be wired by hand) and runs a version of linux.
  • Prophead100Prophead100 Posts: 192
    edited 2010-12-19 18:36
    A couple suggestions. First, unless your worried about oil in the bilge then you may want the bilges to run automatically separately from the monitoring system and have the SMS be more of a heads up to come check it out. Turning the lights on or something so nearby boaters notices would be a good touch. In looking at a similar system, I also added a memsic 2125 tilt sensor to watch if the boat is listing and separated the bilge sensors by compartment to help give an idea of what might be leaking before you get there or assess risk ( the chain locker is better than an engine room).
    edited 2010-12-19 21:39
    I really like the tilt sensor idea, the boat is an old Erwin sailboat and really has only one bilge but I have three bilge pumps in it, two of which operate automatically. the two that operate automatically are set high in the bilge. higher then 80 gallons of diesel fuel could set off. The boat lives in a protected marine sanctuary in the Florida keys were any discharge of oil or fuel is met with very stiff fines often in the hundreds of thousands of dollars. for the most part the boat is very dry but the occasional passing hurricane I often pick up a couple inches of water in the bilge and it'll be nice to be able to send an SMS message and turn on the bilge remotely especially when they call for mandatory evacuations.
    I wonder if using the tilt sensor if you can tell the difference between somebody stepping on the boat or the wind just causing it to rock back and forth you would probably need a gyro to to be of the measure the rate of change but that would be an interesting use.
    edited 2010-12-19 22:03
    Kevin: the cheapest sensor for this would be a gyro and accelerometer - look up the Wii Nunchuck and the Wii Motion Plus - you can interface them using I2C. Try hackerspace or similar.
    edited 2010-12-20 17:41
    I have one of the Wii clone controllers...... sounds like a good reason to take it apart
    edited 2010-12-20 23:08
    On the bilge, you may want to consider one of the Etapes liquid level sensors so you can assess the rate of water (up to 12 inches) coming in to determine the urgency and estimate when the pumps might kick on.
    The tilt sensor could probably differentiate a person from the waves most of the time in that pattern (rate & extent) of roll changes abruptly and the boat lists toward the dock temporarily and roll is interupted. A person can detect that even on our 82' steel cutter in relatively calm conditions so a sensor should be able to do the trick on a more tender vessel. A similar pattern would be set off by tall waves pulling the lines taught against the cleats which is another situation you might want to know about. Another sensor I had looked at but not explored is attaching a strain gauge or flex sensor to a snubber on the line to sense the relative pull/slack of the lines to identify stress from the wind. Another way to get at the stress on the lines is to calculate the sail pressure on the hull and superstructure based upon the wind speed and direction.
    edited 2010-12-20 23:12
    To determine which tilt sensor, take a look at the roll, pitch and yaw rates as the boat in at rest. The gyros may be better for faster movements and the tilt (eg. Memsic 2125) for slow movement, absolute angle, G force, and listing.
    edited 2010-12-20 23:42
    I have a cat so it is inheritantle more stable than a yacht.
    Kevin, the main Wii controller is an I2C master and apparently will not transmit it's info down the I2C pipe (according to the hack websites anyway). However, it may be possible to chat to it via WiFi (IIRC that's what it uses for comms to the main unit).
    edited 2010-12-21 15:31
    Hummm.... I have been looking at a 6DOF IMU for another project that I've been working on, it may be easier to do that than try to hack the Wii controller.it's a bit pricey but should save some time and frustration over going the other route. I think the difficult part is going to be how to differentiate between waves/wakes and somebody stepping on board. You would think that you might be able to even determine if a dock line broke. With measuring the angles of the deflection you should be able to to make a pretty good guess on how much the person weighed that stepped on the boat. Lots of interesting things to think about I first need to get the Xbee working the way I want.
    edited 2010-12-21 17:11
    I have a pcb which does 10DOF coming (gyro, accelerometer, compass and pressure/temp). Still not sure how I will go at soldering the QFNs. Presently it is a seperate pcb approx 1"x2" and has I2C connection. Currently the design will plug into a 1.75"x1.75" prop pcb that I have designed (also coming). Hopefully I can send the pcbs off over xmas for production - I have a group of pcbs to be done, and little time :(
    I am wanting the pcbs for my QuadCopter design and my RepRap design, plus some others. Of course, my QuadCopter is the beginning of an autopilot for my boat (to backup "George", my trusty Navman autopilot).
    edited 2010-12-21 18:19
    ]You can put me down for all three.....I'm assuming they are propeller-based (quadcoper,reprap)
    Have you looked at the Black & Decker reflow oven(infraWave) I picked one up online for under 100. I haven't had a chance to run any boards through it yet but it rocks on frozen egg rolls lol
    Your quadcopped board would be perfect for this hybrid lighter-than-air/heavier-than-air winged blimp project I have been messing with. The thing is 15 feet long and should have a net lifting capacity of over 5 pounds. The pictures I have are not real clear but basically it starts with a rigid frame made from carbon fiber spars covered in rip stop nylon with a zero pressure bladder and high pressure bladder inside use for buoyancy control. For the first attempt at it and making patterns and doing the sewing myself it did not come out too bad but has a bit of a twist to it. I need to lay out a 3-D model so I can convert it to flat panels and have a cad cut and sewn in a sail loft....... somebody they can sewe with precision
    Attachment not found.
    1024 x 613 - 48K
    1024 x 613 - 81K
    1024 x 613 - 52K
    1024 x 613 - 49K
    1024 x 613 - 75K
    1024 x 613 - 63K
    1024 x 613 - 76K
    1024 x 613 - 47K
    edited 2010-12-21 20:41
    Wow. Nice project. What are you filling the blimp with (i.e. helium) ?
    From what I understand, the sail lofts glue the seam with double sided tape before before they sew it. No such luxuries when I used to make my sails when I was a teenager (a long time ago). I did however, cut my material using a soldering iron, which had the advantage of selving (sealing) the edges. Electronics and computers got in the way of my sailing :)
  • bsnutbsnut Posts: 521
    edited 2010-12-22 00:34
    Kevin,
    I love your idea. I am doing a monitoring system on a ship that I am helping to restore and is the USS Zuni/USCG Cutter Tamaora. The Tamaora was the one that did the real rescue in The Perfect Storm, that the book/film was based on. Are system was going to use OPTO22 brain board and 24 I/O board that monitors the fire alarm, bilge alarm and the 460VAC/3PH incominng shore power connection.
    We were looking for a cheep way to talk to the OPTO22 brain board and your idea maybe the ticket for us. Are you paying extra on your cell phone service and which gsm modem are you using?
    Are you connected to shore power? If you are, I would monitor the shore power for power loss. This will let you know two things
    1) Your lines may have broken and your sail boat foating away without you.
    2) You are on the backup or house battery.
    The idea of using a tilt sensor is a great idea and it gives me the idea to put one on our ship. But, I would mount it low and on the centerline of your sail boat.
    edited 2010-12-22 07:06
    Hi bsnut,
    I'm using a Tellit GM-862 -- GPS And a Spark fun breakout board. it is a GSM module and will only work with AT&T and T-Mobile there might be some other small carrier
    it works with but I'm not aware of. You will also need a SIM card that goes into the module. I am using T-Mobile prepaid account for access to the device all the prepaid accounts that I looked at have a parasitic charge that depletes the account even though the phone is not being used. With T-Mobile if you purchase $100 or more the minutes will not expire for 12 months. So basically I pay $100 per year for service that will give you 1000 minutes or about 400 SMS messages at $.25 apiece in or out. The easiest way to get a sim card is to purchase one of the cheap prepaid phones I paid $10 for the one I use.
    keep the phone, user to activate the account and to recharge the account
    I'm using 2 6ah 6v sealed lead acid batteries with a small array of 9 V solar panels so it is completely separate from all other ship systems. I monitor the 12 V system but currently not monitoring the AC power. Hopefully the GPS will let me know if the boat starts to drift away. I plan to set it up with guards zones so if it drifts it will phone home.
    on your power monitoring make sure your monitor all three legs, I've had one leg drop out on me before and caused some problems
    Kevin
  • BeanBean Posts: 8,129
    edited 2010-12-22 11:20
    The nunchuk is straight I2C. And it has an accellerometer.
    Also a digital compass could tell if the boat is loose or drifting.
    Bean
    edited 2010-12-22 11:40
    Kevin: I am interested in your Telit AT code as I now have a Telit GE-864Quad for this. Here in Oz I will connect to Telstra although it is not NextG (up to 21Mbps) as far as I can tell.
    Bean: A digital compass will not tell if my boat is loose or drifting as I have it anchored outside the house and tied to shore. However, it moves considerably with wind and tide - unfortunately the bad winds are onshore from S and the W.
    A GPS would be the best choice. I have one of the older modules from Parallax. They are cheap. The guard band would need to be set properly for my boat as I would want a shore line barrier so I guess what I would require is a sector of a circle (i.e. a piece of a pie chart). This would not be too difficult to set up. Just plot the anchor position, the chain let out (plus the distance the GPS is from the bow), then minimum depth (low tide), and the arc (in degrees) and the direction of the centre of the arc. Now all could be quite simply calculated, with a small variance for GPS error. If the boat is not in the arc then something is wrong - Phone Home ET !
    edited 2010-12-22 12:09
    cluso,
    I included it with the first post it is PropVMS.spin
    you may have to fuss with it a bit. You can see some of the other commands that I've commented out in the gsminit once I had the module configured I was able to reduce the commands to only a couple everything worked fine even with roaming. But if you turn the unit off and move to new location i.e. out-of-state it would not automatically reconnect when you powered it back up. The current configuration will it take longer to boot and initiate the GSM but I've tested it off and on moving to different locations in the country and it connects every time.
    really haven't added any debug code because I was using a logic Prob to monitor the interface between the prop and GSM I had some problems originally with it but it came down to simply adding some delays between commands to allow for the replies from the module things happen slower than you would expect them to, is the reason for the large delays but really is comparable to when you power up your mobile phone I guess I'm just used to the prop doing everything so fast LOL
    GSM.str(String("AT+BND=1", cr)) 'set to north america you will need to change BND=3 for down under I think
    edited 2010-12-22 14:10
    [QUOTE=Cluso99;962756Bean: A digital compass will not tell if my boat is loose or drifting as I have it anchored outside the house and tied to shore. However, it moves considerably with wind and tide - unfortunately the bad winds are onshore from S and the W. [/QUOTE]
    Oh, I was thinking it was tied to a dock.
    Bean
    edited 2010-12-23 02:25
    Kevin,
    I will be looking into the GSM Module for our ship.
    edited 2010-12-23 14:59
    If its at anchor, then perhaps looking for wind abeam is a better measure of a broken anchor line. It wouldn't work for dragging though.
    Bean wrote: »
    Bean
    edited 2010-12-23 15:06
    What kind of circuit or device might be monitoring the [shore] power? ( My project is on a smaller cutter (point class) with the same short power requirements as the Tamaora)
    bsnut wrote: »
    Kevin,
    edited 2010-12-23 18:16
    PropHead,
    normally ships requiring 460v 3 phase power have a central power distribution center were voltage and current are measured this is typically where you would want to attach the remote monitoring system. But if the vessel is very old it may not be equipped so it comes down to a couple choices current Transformers are shunts. I personally prefer current Transformers, but it's like anything I really don't know what you have so it is hard to say. On the low-tech side I've used simple power cubes that output a simple voltage 3v 5v 6v 9v dc or ac you just have to make sure you get a transformer on each leg 460v 3phase consists of three hot leads each at 220 V that can be used directly for big electric motors or run through transformers to bring it down to 110v even if it's not many power cubes are designed to operate at 220 V for sale in Europe they make it quite simple and effective interface for measuring/monitoring line voltage
    edited 2010-12-23 20:18
    Thanks Kevin - I forgot you posted the code. At that point in time I was not sure what I would do.
    I am actually at anchor but with 2 stern lines to shore as well. But after Xmas I will have to move to a mooring and here is where I really see the danger of vandals or theft. When I was on the dock it was safe because of security patrols. My neighbour lived on his boat with a dog so it was extremely safe, and we were living on it too most of the time.
    My 240Vac inverter is off when I am ashore as it takes 1A+ just to idle unless absolutely nothing is on. I have 510AH of 12V AGM batteries for the house. I use an 2M approved LED anchor light.
    In Australia, we do not have roaming as such. So, Telstra has the best coverage over the whole country. IIRC it is over 95% of all the population. So the roaming is not a problem here. One bill covers the whole country :) FWIW when I was in the US for Comdex in 1996, there were 3 of us with our wives. We only saw 1 mobile phone. We had 8 between the 6 of us (the 2 sales guys had 2 each!). At that time, a temporary cell tower had to be fitted on-site for the incredible demand for our "small" electronics show.
    edited 2010-12-23 21:35
    Cluso,
    The problem I was having had to do more with tower Association. When the unit is on in your moving it automatically passes tower IDs as you move. With the power off moving to a new location i.e. new tower, same provider,when you power the device up it wants to reconnect to its last known association and was not picking up the new tower ID the current configuration solves that.
    I was thinking about how to set up the guard zone, it really is quite simple, rather than trying to figure out all kinds of angles. Way too difficult for me..... a guard zone is nothing more than a distance calculation from a constant. if you break it down there is really only two two basic ways to secure a boat. You have a single point mooring such as anchor or mooring ball. Or you have a multipoint mooring two anchors, a 3 anchor configuration like your boat, 4 or more anchor is the dock. The only difference between the two types is where you mark waypoint zero your center of rotation. In a single point mooring would ideally want the antenna receiver directly over the spot you drop the anchor which would make your guard zone equal your scope plus a little fudge room or just measure the distance as your backing down on the anchor. in a multipoint mooring the boat becomes the center of rotation not the anchor spot. If you turn on your chart plotter and let it run for a day or two it will draw nice pretty circles on the screen for you. So ideally waypoint 0 /center rotation would be set with the boat all tied up, with no wind waves her current. So regardless of how you tie up your boat or guard zone consolation never has to be more complex than the distance to waypoint zero.the only difference becomes where you mark waypoint zero.
    edited 2010-12-23 22:15
    Kevin: Yes, quite true. It's amazing to look at a plot overnight, particularly in a storm. One evening we were anchored in the sea behind a headland and a storm came through overnight - 53Kts! I slept on the lounge that night with my Plotter alarm on.
    edited 2010-12-24 07:22
    I provided a drawing from my monitoring system that I am working as well. As you can see a transformer is connected to two legs of the 460VAC. This transformer is 460VAC Primary 120VAC Secondary for the pilot lights and Aux contact on the Port Shore Power breaker which was existing to the switchboard. The only thing that I will be adding, is the relays that you see in the drawing. When you loss one or both legs of the 3phase the 120 volt secondary will not work and the monitor relays that I will be installing will not work at all.
    The switchboard that we have is around 1980's vintage. I can give you the exact date of the switchboard when I go back to the ship later this month if you want. I hope this gives you idea what I have on our ship.
    Prophead100,
    What is the name for your smaller cutter (point class) and when did serve in the USGC?
    Happy Holidays to you all.
    edited 2010-12-24 21:35
    Thanks bsnut. We have two of the 3-phase 460/480 generators that need monitoring especially at night on top of the standard night watch. We use them for the crane, welders and power as we are out.
    Our point class cutter is the 82' Point Weber, named after its current location. ( http://www.pointweber.org/documents/ourship.htm) It was built in 1962 for Coast Guard and transferred to the Navy as a workboat retrieving missles off the coast of southern California until the 90's when it was surplused to the SeaScouts. A nice bonus is a crane on the back.
    displayimage.php?pid=2278&fullsize=1
    bsnut wrote: »
    Prophead100,
    edited 2010-12-25 03:09
    Prophead100,
    I saw your group's website and it's a cool boat and was surprised what was on the inside.
    I also pm you with some questions and give our website, which is this WWW. Zunitamaora.org and about the monitoring that your wanting to do.
