How to run a dc motor with basic stamp microcontroller?
Hi I want to know that how do you run a 5V dc motor with basic stamp. Do you need any relay to run the dc motor? And if a relay is required then is it just simple programming to turn it on and off. I just want to use the motor as a fan for project. Like High ... to turn the motor on and low... to turn it off..
Thanks in advance.
Thanks in advance.
wiresalot
Use a transistor and you have the option of speed control too
