Stingray robot motor control
Hi all,
I bought the Stingray robot. I used the Pings on a Stingray robot program that is supported by Parallax.
This program is using the "PWMx8" library and SetMotor(Motor, Speed) method. The max. speed setting is 255.
I want to make my robot more faster using simple way.
How can I run my motor more faster?
I don't know which code exactly that you are using. Up in the constants section, there should be a max speed setting (if I remember correctly, it was set at 100). Try adjusting that up and down slowly to see how the robot responds - but be careful - if you do a little search, you will find posts from some Stingray owners who dented up a few walls!
Edit - The constant that sets the max speed is not present in the most recent Pings on a Stingray code. I'm not certain how it works on the most recent code. Sorry.
You could change your gearmotors to get higher RPM at lower torque, or you could add external motor controllers (like HB-25s) and a higher-voltage motor battery if you really want to get into baseboard-bashing. Post some video!
