I need some help with a 32 bit PASM divide routine...
Hi folks,
The code fragment below is something I copied off of the forums a while ago - not sure how long ago. I have not idea if it is complete or works yet - I am hoping so because I have no clue how it works or how to do something similar.
Anyway, my question is how many clock cycles will this take to execute? If values matter, the following would be typical of the values I would use...
100,000 / 700
Below is the code I copied from some generous author.
Chris
divide mov temp,#32 ' Divide a 32 bit unsigned dividend
mov remainder,#0 ' by a 32 bit unsigned divisor to
:loop shl dividend,#1 wc ' get a 32 bit unsigned quotient
rcl remainder,#1 ' and a 32 bit unsigned remainder
cmpsub remainder,divisor wc,wr
rcl quotient,#1
djnz temp,#:loop
divide_ret ret
temp long 0
dividend long 0
remainder long 0
divisor long 0
quotient long 0
100,000 / 700
Chris
rcl quotient,#1
djnz temp,#:loop
divide_ret ret
temp long 0
dividend long 0
remainder long 0
divisor long 0
quotient long 0
(5 * 32 + 3) * 4 = 652
If I look at your typical values, then a 32bit / 16bit division may also work. Here is a code from an early Prop Document from Chip:
' ' Divide x[31..0] by y[15..0] (y[16] must be 0) ' on exit, quotient is in x[15..0] and remainder is in x[31..16] ' divide shl y,#15 'get divisor into y[30..15] mov t,#16 'ready for 16 quotient bits :loop cmpsub x,y wc 'if y =< x then subtract it, quotient bit into c rcl x,#1 'rotate c into quotient, shift dividend djnz t,#:loop 'loop until done divide_ret ret 'quotient in x[15..0], remainder in x[31..16]This needs only (3 * 16 + 3) * 4 = 252 clock cycles
Andy
Thank you very much. I see too how you figured out the number of times through the loop, that was what I had not idea how to determine.
Yes, the full range of my divisor value will fit in 16 bits so your suggestion will save me a lot of cycle time!
Chris
