Jumper cables 1pin M-M & F-F for prototyping — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2010-12-07 22:39 in Propeller 1
I just wanted to bring to your attention some cables I found. I have not bought any, do not know the company, so use at your own risk.
http://www.cutedigi.com/index.php?cPath=243_288&osCsid=4e008ad77bc40ac4c2b717eb89c1fe05
I use jumpers I made over 30 years ago which have M-M, M-F and F-F and have found them an invaluable tool when prototyping or testing. They are similar but use the RS232 pins so do not work as well as proper pin stake cables.
I realise this is not the correct thread, but posting elsewhere is likely to be missed.
    edited 2010-12-07 17:14
    The truly nice thing about jumper wires with attached connectors is that the wires can be flexible but with ends that don't unravel or become flaccid.
  • schillschill Posts: 741
    edited 2010-12-07 18:03
    These kinds of jumper wires have been showing up a lot lately in a bunch of different places. After years and years of making my own, I've started buying them so that I have them around when I'm in hurry. I get them from www.pololu.com . You can get wires with male and female ends and buy the housings separately - making it easy to make custom multi-conductor cables.
    http://www.pololu.com/catalog/category/39
    They are compatible with the terminals and housings that I've been buying for years from places like www.jameco.com .
    I have male and female pins and some housing on order in large quantities. But I am not buying cables so you will have to make your own. However, these are a great cheap solution for those odd prototypes and playing.
