Low voltage coin-cell and Propeller does work
I don't mean to double post, but I felt I should add this thread just in case someone in the future needs to run a Prop off a coin-cell. There wasn't much information available when I was researching this.
I found the the Propeller has no problem running off 2.9 V CR2032 and RCFAST internal oscillator. You can read more about it here. I haven't tested how long my circuit runs, but it seems like a reasonable amount of time for a simple demo circuit like my calling card.
There seems to be some hysteresis in the circuit. On a bench supply it seems like circuit doesn't turn on until VDD is swept up to 2.86 V, but it keeps running until it is swept down to 2.84 V. Take this data with a grain of salt, as I may be overlooking something obvious.
To reiterate, with either internal oscillator, and a CR2032 coin-cell, the Prop has no problem blinking lights and running loops. I'll add a follow up if I ever try to run it with a crystal.
That won't fit in my wallet! What about a credit card size photocell ? I mean solar panel. That way you don't use power till you take it out of your pocket?
"What about a credit card size photocell?"
...actually if it were a credit card sized "solar cell" instead of a photocell it would be just about right.
At roughly .077 Watts per square inch, a credit card would come in at just over 7 square inches ... 0.539 Watts
Power = Current x Voltage
0.539 Watts / 3.3V = 163mA ... perfect for the Propeller
Actually to get the MPP (Maximum Power Point) right the solar cell will need to be configured at about twice the voltage, so...
0.539 Watts / 6.6V = 81.6mA ... Still a respectable amount
But then the potato option wouldn't be much good either, the crops are frozen in the ground (and then the lemon got drowned in some G+T)
So what we need is a weeny alcohol powered fuel cell http://www.sciforums.com/showthread.php?t=70553
Drop the business card into a G&T (minus the T is probably better) and it starts to do it's thing.
The prop can go into sleep mode most of the time and you could charge up a small rechargeable battery with the solar panel, then when you want to do a demo there will be plenty of juice.
I do not have any Sulphuric acid for that fuel cell experiment, wouldn't vinegar be better for our chips??
(Thankyou very much, I'm here 'till Thursday, TISH)
http://en.wikipedia.org/wiki/Baghdad_Battery
-dan
Bill
My daughter brought home a computer she designed for me. It was just a mock-up, she's in 3rd grade. It was shet of notebook paper folded into 16ths. On one side, each little box was the cover of a "video game" like tetris and sudoku. Unfolding it to a two box size was a cell phone, and finally the full sheet (with one fold down the middle) was a clam-shell laptop. It was really cool, I've been thinking how to build this type of from - configurable, modular device.
Now, what about a three board affair with a solar panel, an LCD, and a keyboard? The LCD and keyboard would have to be a little bigger than a credit card maybe, but Ive seen cell phones with full keyboards that are about that small. If it was membrane keyboard, just the buttons without the keys? and a monochrome LCD instead of color? Could a solar panel charge super capacitor enough to run a prop? I realize this might be a little excessive for a business card, but hey, if you want to make an impact, this ought to do it!
I'm going to revisit my old 8x8 LED matrix badge, this time redesigned with fewer parts on a shiny black PCB. Should be able to get the price to less than $15 each. You can have CGoL playing on your chest.
