Propeller Backpack and xbee
Tumbler
From the propeller backpack info sheet:
Now i was wondering, can an xbee connected to the backpack?
Or do i need to make some changes in the bp-firmware?
Communication with the Backpack video terminal program takes place using serial I/O, transmitting and
receiving at 9600 baud, using a non-inverted, open-drain protocol.
None of these techniques will permit programming the Backpack via XBee, though; but I'm working on a solution to that this weekend, as well as finishing up an XBee daughterboard design. More soon...
Only the 'white' marked pin (3pin header) goes to the propeller A27 pin.
So it's a bit confusing, and i don't want to programm the propeller wirelessly, only send commands to it using some xbee's
