Program Code Help
Hello, I'm new to the Basic Stamp and PBASIC.
I'm looking for some help with my code.
I have the Stamp USB Kit and this is my code:
that talks about interfacing the ADC0831/2 with the BS2. I have a
similar set up and I'm using two IR distance sensors on Channel 0 & 1.
The problem I'm having is where the code says...
I can get it to execute the check_0 subroutine which lights up my first led (LED0)
but the second IF...THEN... command doesn't seem like its working at all.
It should be lighting up my second led (LED1) if the conditions are fulfilled,
and I know that they are, but it doesn't even blink.
Is there something wrong with my code? I've tried looking it over but I can't
figure out what it could be. Thanks in advance for your help out there!
' ========================================================================= ' ' File...... ADC08x32.BS2 ' Purpose... Experiments with the ADC08x32 ADC ' Author.... Jon Williams ' E-mail.... jwilliams@parallax.com ' Started... ' Updated... 06 DEC 2004 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[ Program Description ]--------------------------------------------- ' ' This program demonstrates the various modes of the ADC08x82 ADC. ' -----[ Revision History ]------------------------------------------------ ' ' -----[ I/O Definitions ]------------------------------------------------- CS PIN 15 ' ADC0832.1 Clk PIN 14 ' ADC0832.7 Dio PIN 13 ' ADC0832.5 / ADC0832.6 ' -----[ Constants ]------------------------------------------------------- Sgl CON %1 ' single ended Dif CON %0 ' differential Raw2mV CON $139B ' 19.6 mV per count ' -----[ Variables ]------------------------------------------------------- sglDif VAR Bit ' adc mode (1 = SE) oddSign VAR Bit ' chan (Sgl), sign (Dif) adc VAR Byte(2) ' channel values mVolts VAR Word(2) ' millivolts ' -----[ EEPROM Data ]----------------------------------------------------- ' -----[ Initialization ]-------------------------------------------------- Reset: HIGH CS ' deselect ADC DEBUG CLS, "ADC08x32", CRSRXY, 0, 2, "Single-Ended", CR, CR, " Ch0:", CR, " Ch1:", CR, CRSRXY, 0, 7, "Differential", CR, CR, " Ch0:", CR, " Ch1:" ' -----[ Program Code ]---------------------------------------------------- Main: DO sglDif = Sgl FOR oddSign = 0 TO 1 GOSUB Read_0832 mVolts(oddSign) = adc(oddSign) */ Raw2mV DEBUG CRSRXY, 7, (4 + oddSign), DEC3 adc(oddSign), TAB, DEC mVolts(oddSign) DIG 3, ".", DEC3 mVolts(oddSign) IF oddSign = 0 AND (adc >= 15) THEN check_0 IF oddSign = 1 AND (adc >= 10) THEN check_1 PAUSE 0100 NEXT LOOP END ' -----[ Subroutines ]----------------------------------------------------- check_0: IF (adc >= 27) THEN HIGH 10 ELSE HIGH 10 PAUSE 0125 LOW 10 ENDIF RETURN check_1: IF (adc >= 30) THEN HIGH 9 ELSE HIGH 9 PAUSE 0125 LOW 9 ENDIF RETURN Read_0832: LOW CS ' send start, mode, channel SHIFTOUT Dio, Clk, MSBFIRST, [%1\1, sglDif\1, oddSign\1] ' read raw counts from ADC SHIFTIN Dio, Clk, MSBPOST, [adc(oddSign)\8] HIGH CS RETURNI'm using the code I found in an issue of Nuts and Volts
I would either add the (oddsign) to the adc values in the IF statements or remove the (oddsign) from all occurrences of adc.
Rich H
GOSUB check_1
ELSE
GOSUB check_0
ENDIF
ENDIF
