Program Code Help
Hello, I'm new to the Basic Stamp and PBASIC.
I'm looking for some help with my code.
I have the Stamp USB Kit and this is my code:
that talks about interfacing the ADC0831/2 with the BS2. I have a
similar set up and I'm using two IR distance sensors on Channel 0 & 1.
The problem I'm having is where the code says...
I can get it to execute the check_0 subroutine which lights up my first led (LED0)
but the second IF...THEN... command doesn't seem like its working at all.
It should be lighting up my second led (LED1) if the conditions are fulfilled,
and I know that they are, but it doesn't even blink.
Is there something wrong with my code? I've tried looking it over but I can't
figure out what it could be. Thanks in advance for your help out there!
' File...... ADC08x32.BS2
' Purpose... Experiments with the ADC08x32 ADC
' Author.... Jon Williams
' E-mail.... jwilliams@parallax.com
' Started...
' Updated... 06 DEC 2004
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' This program demonstrates the various modes of the ADC08x82 ADC.
' -----[ Revision History ]------------------------------------------------
' -----[ I/O Definitions ]-------------------------------------------------
CS PIN 15 ' ADC0832.1
Clk PIN 14 ' ADC0832.7
Dio PIN 13 ' ADC0832.5 / ADC0832.6
' -----[ Constants ]-------------------------------------------------------
Sgl CON %1 ' single ended
Dif CON %0 ' differential
Raw2mV CON $139B ' 19.6 mV per count
' -----[ Variables ]-------------------------------------------------------
sglDif VAR Bit ' adc mode (1 = SE)
oddSign VAR Bit ' chan (Sgl), sign (Dif)
adc VAR Byte(2) ' channel values
mVolts VAR Word(2) ' millivolts
' -----[ EEPROM Data ]-----------------------------------------------------
' -----[ Initialization ]--------------------------------------------------
Reset:
HIGH CS ' deselect ADC
DEBUG CLS,
"ADC08x32",
CRSRXY, 0, 2, "Single-Ended", CR, CR,
" Ch0:", CR,
" Ch1:", CR,
CRSRXY, 0, 7, "Differential", CR, CR,
" Ch0:", CR,
" Ch1:"
' -----[ Program Code ]----------------------------------------------------
Main:
DO
sglDif = Sgl
FOR oddSign = 0 TO 1
GOSUB Read_0832
mVolts(oddSign) = adc(oddSign) */ Raw2mV
DEBUG CRSRXY, 7, (4 + oddSign),
DEC3 adc(oddSign), TAB,
DEC mVolts(oddSign) DIG 3, ".", DEC3 mVolts(oddSign)
IF oddSign = 0 AND (adc >= 15) THEN check_0
IF oddSign = 1 AND (adc >= 10) THEN check_1
PAUSE 0100
NEXT
LOOP
END
' -----[ Subroutines ]-----------------------------------------------------
check_0:
IF (adc >= 27) THEN
HIGH 10
ELSE
HIGH 10
PAUSE 0125
LOW 10
ENDIF
RETURN
check_1:
IF (adc >= 30) THEN
HIGH 9
ELSE
HIGH 9
PAUSE 0125
LOW 9
ENDIF
RETURN
Read_0832:
LOW CS
' send start, mode, channel
SHIFTOUT Dio, Clk, MSBFIRST, [%1\1, sglDif\1, oddSign\1]
' read raw counts from ADC
SHIFTIN Dio, Clk, MSBPOST, [adc(oddSign)\8]
HIGH CS
RETURN
I'm using the code I found in an issue of Nuts and Voltsthat talks about interfacing the ADC0831/2 with the BS2. I have a
IF oddSign = 0 AND (adc >= 15) THEN check_0 IF oddSign = 1 AND (adc >= 10) THEN check_1
I would either add the (oddsign) to the adc values in the IF statements or remove the (oddsign) from all occurrences of adc.
Rich H
GOSUB check_1
ELSE
GOSUB check_0
ENDIF
ENDIF
