C2H5OH (Alcohol / Benzine) Gas Sensor
I am hoping to be able to use the C2H5OH (Alcohol / Benzine) Gas Sensor as a Benzene detector. The datasheets for this product mention that it has a high sensitivity to alcohol, and a small sensitivity to benzene. All of the parameters listed are for alcohol detection, as I assume it's main use would be for a breathalyzer application. I was wondering if there were any minimum and/or maximum limits set for the amount of benzene that this sensor will detect?
You don't have benzene floating about it, do you? It's nasty stuff.
The first thing is to establish what you mean to "detect smaller quantities of the nasty stuff". The MQ-3 data sheet shows response in the range of 0.1 to 10 mg/l. It is dangerous to extrapolate with these sensors. What are the NIOSH standards for benzene (benzine?) exposure?
From the sensor standpoint, there may be a strong difference between the chain-like structure of the alcohol/benzine and the ring structure of benzene. I thought it might be the OH group on the alcohol, but evidently not. I really wonder how they achieve specificity in these metal oxide (usually tin dioxide) catalytic sensors.
I took a look at the e2v gas sensor offerings. The sensors they recommend for benzene are primarily meant for carbon monoxide+hydrocarbons+VOCs. They are not well characterized though, even for CO. Cheap at $7 each, compared to their NDIR (mine safety, explosive limit) sensors at $264 each.
I see NIOSH and OSHA have 8hr/40hr week exposure limits of between 0.1 and 1 ppm. OSHA: 5ppm max for 15 minutes. NIOSH: acute immediate toxicity at 500ppm.
0.1 mg of benzene in 1 liter of air is about 28ppm, by my calculation.
I must have been well over those limits when I was using benzene to clean that stuff off the floor tiles. One of my job functions was Safety Officer for that facility!
