C2H5OH (Alcohol / Benzine) Gas Sensor — Parallax Forums
melinda_nsccmelinda_nscc Posts: 5
edited 2010-11-30 12:46 in Accessories
I am hoping to be able to use the C2H5OH (Alcohol / Benzine) Gas Sensor as a Benzene detector. The datasheets for this product mention that it has a high sensitivity to alcohol, and a small sensitivity to benzene. All of the parameters listed are for alcohol detection, as I assume it's main use would be for a breathalyzer application. I was wondering if there were any minimum and/or maximum limits set for the amount of benzene that this sensor will detect?
  • LeonLeon Posts: 7,620
    edited 2010-11-30 02:36
    You'll probably have to work it out for yourself and calibration will be a problem. You can buy benzene sensors, of course.
    You don't have benzene floating about it, do you? It's nasty stuff.
  • melinda_nsccmelinda_nscc Posts: 5
    edited 2010-11-30 03:04
    I certainly hope I don't!! I just wanted to make sure that it will detect smaller quantities of the nasty stuff. I realize I will have to calibrate it for my use. Thank you for your reply.
    edited 2010-11-30 04:39
    Many years ago, before it was known to be dangerous, I was told to use it for removing concrete floor sealant that one of my maintenance staff mistakenly applied to some plastic floor tiles. I tried it for myself and must have breathed in a lot of it.
    edited 2010-11-30 09:07
    You are referring to the Hanwei MQ3 sensor from Parallax (#605-00011), or maybe the digital output module (#27904)?
    The first thing is to establish what you mean to "detect smaller quantities of the nasty stuff". The MQ-3 data sheet shows response in the range of 0.1 to 10 mg/l. It is dangerous to extrapolate with these sensors. What are the NIOSH standards for benzene (benzine?) exposure?
    431 x 383 - 38K
    edited 2010-11-30 09:10
    Benzine is petrol, IIRC. Benzene is C6H6.
    edited 2010-11-30 09:12
    That's not good!! Not growing any extra limbs or anything, are you?
    edited 2010-11-30 09:19
    It was over 40 years ago.
    edited 2010-11-30 09:24
    Thanks Tracy. I guess I should clarify that I'd like to detect benzene from furnace oil (fuel oil #2) in the air, should there be a leak. That is what I mean by smaller quantities. I'm running with a benzene sensor right now, because it's for a school project and my need is based on being able to quickly order a product, as I need to build my project within 3 weeks. EEK!
    edited 2010-11-30 09:31
    Speaking of "good cleaners gone bad", check this article on brake cleaner and phosgene gas: http://www.brewracingframes.com/id75.htm
    edited 2010-11-30 11:46
    Thanks Leon about the difference between benzine (= mixture of pentane, hexane etc. chain hydrocarbons) and benzene.
    From the sensor standpoint, there may be a strong difference between the chain-like structure of the alcohol/benzine and the ring structure of benzene. I thought it might be the OH group on the alcohol, but evidently not. I really wonder how they achieve specificity in these metal oxide (usually tin dioxide) catalytic sensors.
    I took a look at the e2v gas sensor offerings. The sensors they recommend for benzene are primarily meant for carbon monoxide+hydrocarbons+VOCs. They are not well characterized though, even for CO. Cheap at $7 each, compared to their NDIR (mine safety, explosive limit) sensors at $264 each.
    I see NIOSH and OSHA have 8hr/40hr week exposure limits of between 0.1 and 1 ppm. OSHA: 5ppm max for 15 minutes. NIOSH: acute immediate toxicity at 500ppm.
    0.1 mg of benzene in 1 liter of air is about 28ppm, by my calculation.
    edited 2010-11-30 12:16
    Right...probably a huge difference between the two. I guess I'll have to take a look at some other sensors to see what they will detect...
    Tracy:
    I must have been well over those limits when I was using benzene to clean that stuff off the floor tiles. One of my job functions was Safety Officer for that facility! :)
