Play movies on the propeller — Parallax Forums
Dr_AculaDr_Acula Posts: 5,484
edited 2010-11-26 22:09 in Propeller 1
The color video thread has evolved to the point of being able to play movies http://www.youtube.com/watch?v=170HLfl6VfI
Of course, having uploaded this, Youtube has kindly linked it with a video by PropGFX showing this was first done back in 2008!
So, belatedly, the video itself is just a single binary file that is played through Kye's 160x120 video driver. Speed works out fast enough to play the video at the right speed. There are enough cogs free for other things (? audio).
Hardware is a prop demo board with an SD card attached to pins 12,13,14,15.
The most complicated part is the pre-processing. Grab a Youtube video with Savetube and run it through AVS4YOU to create hundreds of bitmap files. Then run a vb.net program to shrink those down to 160x120 and reduce the color depth to 64 colors.
New vb.net code automates the process of creating screens from bitmaps of any size.
Spin code uses Kye's objects from the Obex.
Propeller Movie player by James Moxham, November, 2010
See also the vb.net program to create the movie files
CON
  _clkfreq = 80_000_000
  _clkmode = xtal1 + pll16x
  _clockDataPin = 29
  _clockClockPin = 28
  _cardDataOutPin = 12
  _cardClockPin = 13
  _cardDataInPin = 14
  _cardChipSelectPin = 15
  _pinGroup = 2
  _switchRate = 5
  ' Keyboard
  NUM        = %100
  CAPS       = %010
  SCROLL     = %001
  RepeatRate = 40
  MaxIcons = 15
OBJ
  pix: "VGA64_PIXEngine.spin"            ' thanks to Kye 160x120
  fat: "SD2.0_FATEngine.spin"            ' thanks to Kye
  kb : "keyboard"                 ' keyboard
VAR
  Word Key
  long i
PUB Main
  ifnot(pix.PIXEngineStart(_pinGroup))
    reboot
  ifnot(fat.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, _clockDataPin, _clockClockPin))
    reboot
  fat.mountPartition(0,0)     ' mount the sd card
  kb.startx(26, 27, NUM, RepeatRate)                  'Start Keyboard Driver if required
  Wallpaper                     ' startup splash screen
  repeat i from 1 to 600000     ' delay for vga screen to warm up
  Movie(837)                    ' play n frames in the movie
PUB Wallpaper
    fat.openfile(string("prop160.vga"),"R")      ' 160x120
    fat.readdata(pix.displaypointer,19200)
    fat.closefile
PUB Movie(n) | d
    fat.openfile(string("taz.pmv"),"R")      ' 160x120 per frame, saved as a binary file
    repeat i from 1 to n ' number of frames
    ' possibly add a delay here
    fat.closefile
And the vb.net processing routine
        Dim sizex As Integer
        Dim sizey As Integer
        Dim PixelValue As Color
        sizex = 160 - 1 ' kye screen is 160x120
        sizey = 120 - 1
        Dim PixelArray(sizex, sizey, 3) As Byte ' R,G,B and calculated prop byte so 4 values
        Dim x, y, i As Integer
        Dim Propbyte As Byte
        Dim OutputArray(20000) As Byte
        Dim t As Integer
        Dim Sourcefile As String
        Dim DestinationFile As String
        Dim StartNumber As Integer
        Dim FinishNumber As Integer
        Dim Filecounter As Integer
        Dim LineofText As String
        DestinationFile = TextBox10.Text + TextBox14.Text
        StartNumber = Strings.Val(TextBox12.Text)
        FinishNumber = Strings.Val(TextBox13.Text)
        Dim OutputVGA As New FileStream(DestinationFile, FileMode.Create, FileAccess.Write)
        For Filecounter = StartNumber To FinishNumber
            Sourcefile = TextBox10.Text + TextBox11.Text ' directory plus rootname
            ' add the right number of leading zeros, (AVS4YOU adds a different number based on how big the total file is)
            LineofText = Strings.Right("000000" + Trim(Strings.Str(Filecounter)), Strings.Len(TextBox12.Text)) ' convert to a string
            Label25.Text = LineofText
            Sourcefile += LineofText + ".bmp"
            ' this little bit of code replaces new sytem.drawing.bitmap as the latter leaves the file locked eg so paintshop can't save a new file
            Dim img As Image
            Dim fs As New FileStream(Sourcefile, IO.FileMode.Open)
            img = Image.FromStream(fs)
            fs.Close()
            ' displa the image in the picture box
            PictureBox4.Image = img
            ' Get the source bitmap.
            Dim bm_source As New Bitmap(PictureBox4.Image)
            ' Make a bitmap for the result shrunk to 160x120
            Dim bm_dest As New Bitmap(CInt(160), CInt(120))
            ' Make a Graphics object for the result Bitmap.
            Dim gr_dest As Graphics = Graphics.FromImage(bm_dest)
            ' Copy the source image into the destination bitmap.
            gr_dest.DrawImage(bm_source, 0, 0, bm_dest.Width + 1, bm_dest.Height + 1)
            ' Display the result.
            PictureBox5.Image = bm_dest
            gr_dest.Dispose()
            Dim MyBitmap As New System.Drawing.Bitmap(PictureBox5.Image) 'image from picture box
            For y = 0 To sizey
                For x = 0 To sizex
                    PixelValue = MyBitmap.GetPixel(x, y) ' get the color
                    PixelArray(x, y, 0) = PixelValue.R ' red byte
                    PixelArray(x, y, 1) = PixelValue.G ' green byte
                    PixelArray(x, y, 2) = PixelValue.B ' blue byte
                    PixelArray(x, y, 3) = 0 ' pre fill the prop byte with %00000000 for Kye's code
                Next
            Next
            ' create the propeller color byte
            For y = 0 To sizey
                For x = 0 To sizex
                    For i = 0 To 2
                        ConvertColor(PixelArray(x, y, i), Propbyte) ' get the value 0-3
                        Select Case i
                            Case 0 : Propbyte = Propbyte * 64 ' shift to red position
                            Case 1 : Propbyte = Propbyte * 16 ' shift to green position
                            Case 2 : Propbyte = Propbyte * 4 ' shift to blue position
                        End Select
                        PixelArray(x, y, 3) = PixelArray(x, y, 3) + Propbyte ' add to existing color
                    Next i
                Next x
            Next y
            'PictureBox3.Image = MyBitmap ' bitmap array to picturebox - need to convert pixelarray back to mybitmap to show the decreased color depth
            ' now turn the pixelarray x,y,3 into a binary file
            t = 0
            For y = 0 To sizey
                For x = 0 To sizex
                    OutputArray(t) = PixelArray(x, y, 3) ' move to output array
                    t += 1
                Next
            Next
            System.Windows.Forms.Application.DoEvents() ' update the display
            OutputVGA.Write(OutputArray, 0, 19200) ' save 19200 bytes
        Next Filecounter
        OutputVGA.Close()
    End Sub
Screenshot of the IDE attached.
  • PerryPerry Posts: 253
    edited 2010-11-26 21:50
    My "stupid video capture" thread seems to be very under rated.
    only "Rayman" seems to have actually tried it.
    The prop can record live B/W video with sound to an SD. It is controlled by a InfraRed remote.
    It is still very primative, I work on it sporadically, but there you will find a black and white video recorder that has a test video of myself.
    That program records audio at every horizontal pulse, I have to change that though, because of the a nine missing horizontal pulses during vertical sync.
    simply change the SD interface to you desired pins and you will see it.
    I have a newer version with a short clip from "The Flintstones"
    I believe it is possible to get it to record color as well.
    http://forums.parallax.com/showthread.php?t=98516&highlight=stupid%2C+video
    Perry
    edited 2010-11-26 21:57
    Recording video? That would perfectly complement being able to play the video back.
    I've ponderd a number of video capture solutions. The one I must get around to testing is to use one of those keychain video recorders that record to a micro SD. Then use Kye's SD code to read back the file and process it.
    B&W video capture could be perfect for robotic applications. Reading your thread now...
  • KyeKye Posts: 2,200
    This makes me smile! =)
