Play movies on the propeller
Dr_Acula
The color video thread has evolved to the point of being able to play movies http://www.youtube.com/watch?v=170HLfl6VfI
Of course, having uploaded this, Youtube has kindly linked it with a video by PropGFX showing this was first done back in 2008!
So, belatedly, the video itself is just a single binary file that is played through Kye's 160x120 video driver. Speed works out fast enough to play the video at the right speed. There are enough cogs free for other things (? audio).
Hardware is a prop demo board with an SD card attached to pins 12,13,14,15.
The most complicated part is the pre-processing. Grab a Youtube video with Savetube and run it through AVS4YOU to create hundreds of bitmap files. Then run a vb.net program to shrink those down to 160x120 and reduce the color depth to 64 colors.
New vb.net code automates the process of creating screens from bitmaps of any size.
Spin code uses Kye's objects from the Obex.
And the vb.net processing routine
Screenshot of the IDE attached.
Propeller Movie player by James Moxham, November, 2010
See also the vb.net program to create the movie files
CON
_clkfreq = 80_000_000
_clkmode = xtal1 + pll16x
_clockDataPin = 29
_clockClockPin = 28
_cardDataOutPin = 12
_cardClockPin = 13
_cardDataInPin = 14
_cardChipSelectPin = 15
_pinGroup = 2
_switchRate = 5
' Keyboard
NUM = %100
CAPS = %010
SCROLL = %001
RepeatRate = 40
MaxIcons = 15
OBJ
pix: "VGA64_PIXEngine.spin" ' thanks to Kye 160x120
fat: "SD2.0_FATEngine.spin" ' thanks to Kye
kb : "keyboard" ' keyboard
VAR
Word Key
long i
PUB Main
ifnot(pix.PIXEngineStart(_pinGroup))
reboot
ifnot(fat.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, _clockDataPin, _clockClockPin))
reboot
fat.mountPartition(0,0) ' mount the sd card
kb.startx(26, 27, NUM, RepeatRate) 'Start Keyboard Driver if required
Wallpaper ' startup splash screen
repeat i from 1 to 600000 ' delay for vga screen to warm up
Movie(837) ' play n frames in the movie
PUB Wallpaper
fat.openfile(string("prop160.vga"),"R") ' 160x120
fat.readdata(pix.displaypointer,19200)
fat.closefile
PUB Movie(n) | d
fat.openfile(string("taz.pmv"),"R") ' 160x120 per frame, saved as a binary file
repeat i from 1 to n ' number of frames
' possibly add a delay here
fat.closefile
Dim sizex As Integer
Dim sizey As Integer
Dim PixelValue As Color
sizex = 160 - 1 ' kye screen is 160x120
sizey = 120 - 1
Dim PixelArray(sizex, sizey, 3) As Byte ' R,G,B and calculated prop byte so 4 values
Dim x, y, i As Integer
Dim Propbyte As Byte
Dim OutputArray(20000) As Byte
Dim t As Integer
Dim Sourcefile As String
Dim DestinationFile As String
Dim StartNumber As Integer
Dim FinishNumber As Integer
Dim Filecounter As Integer
Dim LineofText As String
DestinationFile = TextBox10.Text + TextBox14.Text
StartNumber = Strings.Val(TextBox12.Text)
FinishNumber = Strings.Val(TextBox13.Text)
Dim OutputVGA As New FileStream(DestinationFile, FileMode.Create, FileAccess.Write)
For Filecounter = StartNumber To FinishNumber
Sourcefile = TextBox10.Text + TextBox11.Text ' directory plus rootname
' add the right number of leading zeros, (AVS4YOU adds a different number based on how big the total file is)
LineofText = Strings.Right("000000" + Trim(Strings.Str(Filecounter)), Strings.Len(TextBox12.Text)) ' convert to a string
Label25.Text = LineofText
Sourcefile += LineofText + ".bmp"
' this little bit of code replaces new sytem.drawing.bitmap as the latter leaves the file locked eg so paintshop can't save a new file
Dim img As Image
Dim fs As New FileStream(Sourcefile, IO.FileMode.Open)
img = Image.FromStream(fs)
fs.Close()
' displa the image in the picture box
PictureBox4.Image = img
' Get the source bitmap.
Dim bm_source As New Bitmap(PictureBox4.Image)
' Make a bitmap for the result shrunk to 160x120
Dim bm_dest As New Bitmap(CInt(160), CInt(120))
' Make a Graphics object for the result Bitmap.
Dim gr_dest As Graphics = Graphics.FromImage(bm_dest)
' Copy the source image into the destination bitmap.
gr_dest.DrawImage(bm_source, 0, 0, bm_dest.Width + 1, bm_dest.Height + 1)
' Display the result.
PictureBox5.Image = bm_dest
gr_dest.Dispose()
Dim MyBitmap As New System.Drawing.Bitmap(PictureBox5.Image) 'image from picture box
For y = 0 To sizey
For x = 0 To sizex
PixelValue = MyBitmap.GetPixel(x, y) ' get the color
PixelArray(x, y, 0) = PixelValue.R ' red byte
PixelArray(x, y, 1) = PixelValue.G ' green byte
PixelArray(x, y, 2) = PixelValue.B ' blue byte
PixelArray(x, y, 3) = 0 ' pre fill the prop byte with %00000000 for Kye's code
Next
Next
' create the propeller color byte
For y = 0 To sizey
For x = 0 To sizex
For i = 0 To 2
ConvertColor(PixelArray(x, y, i), Propbyte) ' get the value 0-3
Select Case i
Case 0 : Propbyte = Propbyte * 64 ' shift to red position
Case 1 : Propbyte = Propbyte * 16 ' shift to green position
Case 2 : Propbyte = Propbyte * 4 ' shift to blue position
End Select
PixelArray(x, y, 3) = PixelArray(x, y, 3) + Propbyte ' add to existing color
Next i
Next x
Next y
'PictureBox3.Image = MyBitmap ' bitmap array to picturebox - need to convert pixelarray back to mybitmap to show the decreased color depth
' now turn the pixelarray x,y,3 into a binary file
t = 0
For y = 0 To sizey
For x = 0 To sizex
OutputArray(t) = PixelArray(x, y, 3) ' move to output array
t += 1
Next
Next
System.Windows.Forms.Application.DoEvents() ' update the display
OutputVGA.Write(OutputArray, 0, 19200) ' save 19200 bytes
Next Filecounter
OutputVGA.Close()
End Sub
only "Rayman" seems to have actually tried it.
The prop can record live B/W video with sound to an SD. It is controlled by a InfraRed remote.
It is still very primative, I work on it sporadically, but there you will find a black and white video recorder that has a test video of myself.
That program records audio at every horizontal pulse, I have to change that though, because of the a nine missing horizontal pulses during vertical sync.
simply change the SD interface to you desired pins and you will see it.
I have a newer version with a short clip from "The Flintstones"
I believe it is possible to get it to record color as well.
http://forums.parallax.com/showthread.php?t=98516&highlight=stupid%2C+video
Perry
I've ponderd a number of video capture solutions. The one I must get around to testing is to use one of those keychain video recorders that record to a micro SD. Then use Kye's SD code to read back the file and process it.
B&W video capture could be perfect for robotic applications. Reading your thread now...
