MCP3202 & LM34 - missing something in the convert from DAC to mV display — Parallax Forums
StempileStempile Posts: 82
edited 2010-12-03 22:24 in Propeller 1
I am very new to spin.
I have tried several of the objects download for MCP3202 and appear to be working. I have CH0 hooked to an LM34 and I am measuring the output of the LM34 with a volt meter.
Specs for MCP3202 indicate the following:
Digital Output Code = 4096 * Vin / Vdd
 My values:
     Vin = .74 (output per volt meter for the LM34)
     Vdd = 3.3
As I display the DEC value of the ADC output to my debug term, I get something close to 918 (as calculated using above). I am not sure how to process decimals properly in spin, nor how to convert that to a mV value that would be equal to the LM34's 'F output. LM34 specs call for the mV output to be the same as the temp in 'F. I will likely be puzzle by signed values too...
Looking for help with spin number converting. Thanks!
    edited 2010-11-23 06:29
    @Stempile
    0.74 / 3.3 * 4096 = 918.4969….. so 918 or something close to that is the raw reading you should get from the MCP3202.
    Since you are using 3.3V or 3300mV as the reference the output represents 3300 / 4096 = 0.80566…. mV per bit. To get the output to represent 1mV per bit you need to multiply 918 by 0.80566… which equals 739.6mV. Since the output of the LM34 is 10mV per degree F we divide the result by 10 to get 73.96 degrees.
    Simplified, the calculation would be 918 * 0.080566.
  • StempileStempile Posts: 82
    edited 2010-11-23 17:57
    kwinn wrote: »
    @Stempile
    The part I am stuck on is within SPIN and how to represent a calculation as you have represented (with a decimal). Next is how to display that as a string for use on an LCD, console or SD file. I am not clear on the the display of the a "." in the result. I have tried multiple variations of shifting things around and I am just not getting it. I suspect I continue to look past something obvious.
    Thanks for the follow up!
    ms
    edited 2010-11-23 21:06
    The simplest way would be to use the floating point package for the calculations and fullduplexserial or one of the other serial drivers for I/O.
    The calculations could be done in 32 bit binary and converted to fixed point decimal as well, but that is a slight bit more complicated.
    edited 2010-11-23 22:01
    Thanks for the tip, I hadn't looked at the float libs yet, will do that next.
    I am still figuring out what the object exchange is all about. I finally started looking there for string stuff shortly after posting. I still have a pbasic mindset, though I have worked with C, just not enough... Messing around with 'FloatString v2' now; haven't got it working yet.
    ms
  • AribaAriba Posts: 2,694
    edited 2010-11-23 23:41
    Don't use Floatingpoint for such simple calculations !
    If you calculate in milliVolts then integer will be good enough:
    mV := ADCvalue * 3300 / 4096
    It is important that you first multiply and then divide, otherwise the intermediate result can be lower than 1.0 (and gets truncated to 0).
    The variables must be longs (32bit).
    To display the value on a LCD:
    (I assume the lcd object has the methodes dec, out and str, like the TV_Text and many other display objects)
    lcd.dec(mV)          'show in milliVolt
     lcd.str(string("mV "))
     lcd.dec(mV/1000)     'show in Volt, first integer part
     lcd.out(".")
     lcd.dec(mV/100//10)  'then decimal places
     lcd.dec(mV/10//10)
     lcd.out("V")
    Andy
    Thanks Andy. I did not have time to get back to this until recently. Your suggestion was what I was looking for.
