How can I control 2 propeller chips w/1 EEPROM? — Parallax Forums
Dan EDan E Posts: 61
edited 2010-11-25 14:16 in Propeller 1
Hi, I'm doing a school project thats need close to 50 I/O's, and I have two 40 pin 32 I/O propeller chips. Is there a way to connect one to the other so that I can control all of the I/O's using just one EEPROM?
    edited 2010-11-12 17:59
    You can have the first prop boot from the eeprom, which then programs the second prop. You can also have the first prop do all the logic work for the second prop.
    Follow my link and if you look at schematic, CUT off all 4884 props except the first one, that is then the master prop controlling slave prop circuit that uses a single eeprom.
    This thread moves far into parallelism and so do attached circuits, program , but it also uses the concept of booting multiple props from a single eeprom & xtal.
    http://forums.parallax.com/showthread.php?t=124343
    The black box audio sequencer boots 4 props from a single eeprom & xtal using the master slave relationship.
    http://forums.parallax.com/showthread.php?t=115258
    edited 2010-11-12 18:26
    You can also use an I/O expander to provide additional I/O pins. A PCA9554 will provide 8 additional I/O pins and can be connected to the same pins used for the EEPROM. You can attach up to 8 of these since they have a 3-bit hardware address that's configurable.
    If you need output-only, you could use 74HC595s to add 8 outputs each. These can be daisy chained so you'd only need 4 I/O pins for a series of them.
  • Dan EDan E Posts: 61
    edited 2010-11-12 22:44
    Thanks, both are very helpful solutions, I will give it a shot this weekend.
    edited 2010-11-20 19:03
    Hi, I was wondering if anyone knew how to write to pins on a slave chip from the master prop chip? Or if it is possible to have one program that can use pins on both chip?
    Dan E
    edited 2010-11-20 20:56
    You can't really do that. In other words, one Propeller can't "control" another Propeller or its I/O pins or anything else in that Propeller. Two Propellers can cooperate with one Propeller sending information to the second Propeller and a program in the second Propeller receives the information and interprets it in order to allow the first Propeller to appear like it's controlling the second one.
    edited 2010-11-20 22:29
    In short, they cooperate.
    edited 2010-11-21 00:05
    Thanks for the help. I think I get it, so I can have the master prop access a program that is copiled into the slave prop, that program in the slave prop when adressed interrupts the main program in the master prop, and the program in the slave prop will be able to use its own I/O's?
    edited 2010-11-21 00:25
    Yep. In short, you must coordinate.
  • obrienmobrienm Posts: 65
    Dan,
    Hi, there are 2 methods, I would use the design pattern perfected by Clock Loop it works very well.
    http://forums.parallax.com/showthread.php?t=124343&page=3
    The other method which is sequential instead of parallel was designed by Godzich, Christian, Ken and Pems in 2008, it also works but has more limitations.
    http://forums.parallax.com/showthread.php?t=107413
    thank you
    /Michael O'Brien
