Slightly OT: Fighting Century Link's 660 wireless DSL unit
I'm curious, (because their customer area is large).
Is anyone fighting with the configuration of Port forwarding with the Zytel 660 wireless unit from Century Link? There is some real weirdness with mine.
OBC
OBC
Usually port forwarding is pretty straight forward.
Are you sure they are not blocking port 80 ?
Alot of providers do that because they don't want you to run a web server.
Bean
Here's the really weird part...
Spinneret server works fine on local workstations: 192.168.2.X
I've loaded a little web server on my PC to see if the port is open.
When the server on the PC is up, the web proxy can see the page. (on the PC)
It doesn't matter which IP address is specified in the Port Forwarding
section of the router. If the PC web server software is running, it goes
to the PC. Never to the Spinneret.
I've disabled the firewall, etc.
Something here is NOT playing by the rules.
OBC
Also, I know it's a basic thing and you probably got it right, but I figured I would mention it just in case. For Web stuff you need to port forward TCP or both TCP and UDP, not just UDP. I say this because most of the time when I've had to make manual port forwards it was for UDP.
I'm having a similar problem with My NETGEAR router, I think?
I can't get the Spinneret web page to open.All I get is "page can not be displayed".
I've changed the FireWall settings; Nothing
I've changed the PORT#; Nothing
I have the IP address of the Spinneret in the write LAN work group.10.0.0.19, My router is 10.0.0.1,My PC is 10.0.0.3
The MAC address I used for the Spinneret is $ c0.3f.0e.75.2c.ef
I can "ping" and "arp -a" the Spinneret and get valid results from both commands.
I'm at a loss;I'm Struggling with this one???
Heres the code I'm using below,I have used ^^^^ to high light the changes I made. only 4 or 5 lines.
Mine seems to re-direct to the PC no matter what IP address is in my port forwarding section. I've even tried fooling it by exchanging the IP of the workstation and the Spinneret.
I've also disabled UpnP, good idea, but didn't change anything here.
Hey, at least I know port 80 isn't blocked.
OBC
OBC:
I have the same problem.redirect to " bing ".This is not My default settings.My default settings are set to "about blank"
Are running XP64?___This could be a 64bit bug?
Hook the Spinneret to some *ahem* free wireless that was floating nearby and things started working perfectly.
If someone manages to get the Zytel wireless 660 working, I'd sure like to know about it. In the meantime, I'm dropping it into a back later and hooking up an older Cisco router for now.
OBC
