S2 Pre-order! — Parallax Forums
S2 Pre-order!
WhitWhit Posts: 4,194
edited 2010-11-30 09:19 in Robotics
  • schillschill Posts: 741
    edited 2010-11-17 13:54
    And it's possible that some people may have even pre-ordered last night :) .
  • WhitWhit Posts: 4,194
    edited 2010-11-17 14:01
    :hop: Green with envy...
    edited 2010-11-17 14:09
    I put in my pre-order as soon as I saw the update last night. I find it hard to resist a $30 savings like that. :) Especially on something cool!
  • BeanBean Posts: 8,129
    edited 2010-11-17 14:32
    Yeah, order two of them.
    Can't wait to see them "in the flesh".
    Bean
    edited 2010-11-17 15:52
    Just ordered my S2!
    Now how about placing those reform-school Penguins in good homes by Christmas?
    The Penguins were built by the Chimney with care,
    In hopes the Parallax fix would soon be there...
  • BaneBane Posts: 41
    edited 2010-11-17 17:31
    Ordered me one yesterday. I never received a confirmation email of my order though...is this normal because its on backorder? Did anyone else get a confirmation?
  • hover1hover1 Posts: 1,929
    edited 2010-11-17 17:41
    Keep prodding, erco...I do every chance I get!
    Ken will have to let go of these sooner or later!
    Jim
    edited 2010-11-17 18:00
    @Bane: Yes, I did get a confirmation email immediately after ordering. Re-check your spam folder. Did you save your order ID number? You can confirm with Parallax.
  • bdickensbdickens Posts: 110
    edited 2010-11-19 11:09
    ordered 4. My son was thinking of starting a robot club at school. I was about to fund a Stingray but decided to get a couple of these so they could run competitions with each other. Can't wait.
    And now i have a hoard of refrigerator-cleaning HS students reading documentation.
    Forgot the cable though. I'll need to add that.
    edited 2010-11-19 20:00
    Okay, I cracked. I was trying to show restraint... Should'nt have downloaded the pdf of the Start-up Guide. :lol:
    It's bad when you start ordering your own Christmas presents...
    edited 2010-11-19 22:08
    Surprisingly, the Startup Guide for "New Red" looks exactly like "Old Blue"; same ten built-in demo routines. Disappointing, given S2's drastically improved capabilities.
    At a minimum, I hope S2's "draw a figure 8" routine invokes the motor encoders to accurately measure distance, instead of S1's rough approximation. It's Christmas; gimme something I can use!
    edited 2010-11-20 15:06
    The GUI is up now too! Go ahead - snoop around...
    edited 2010-11-21 07:47
    @Parallax & PhiPi: Some cool Christmas Spin code (given S2's encoders) would be to draw some various accurate Spirograph patterns. Ain't that what Scribblin' is all about?
    Surely this sounds like an honest & earnest request for the kiddies, but I have far more selfish motivations in mind. Inasmuch as I'm still not too conversant on the Prop & writing or uploading files, it would be nice for a us Prop virgins to have a step-by step hand-holding primer on a getting starter Spin file up and running on the S2.
    Any possibility of that? :)
    edited 2010-11-21 09:29
    erco,
    1. Install the Propeller Tool software on your computer.
    2. Connect the S2 to your computer via Serial cable or a USB to Serial Adapter, and make sure it is powered on.
    3. Run the Propeller Tool, and load the *.spin file that you want to run on the S2.
    4. Press F10 to load into RAM, or F11 to load into EEPROM.
    It's that simple. :)
    edited 2010-11-21 09:35
    I just preordered one of these! I plan on using spin/pasm only and not the GUI to program mine and will share all of my exploits with the spin beginners here.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-11-26 13:11
    Motors | 2 DC motors provide 20-80 RPM wheel speed
    What does this mean? I would have thought that the speed would be controllable from 0-80 RPM. Or does it mean that the top speed is anywhere from 20-80 RPM?
    Rich H
    edited 2010-11-26 16:11
    Rich,
    The speed range that I measured on my static test stand is more like 11 to 83 r.p.m. The speed of the faster wheel is controlled by an integer from 0 (stopped) to 15 (maximum speed). The speed of the slower wheel is coordinated to the faster one to produce the exact speed ratio selected by the programmer. Here's a chart obtained from my readings for the faster wheel:
    You will notice that the speed for a setting of 1 is the same as that for 2. This is because the S2 object sets a minimum speed of 2 for the faster wheel, in order to guarantee smooth motion.
    The actual top speed at the high settings is a function of battery voltage and motor load. On my chart, it tapers off a bit, probably because I'm using 1.2V NiMH batteries that haven't been charged recently. When this happens, the motor controller for the faster motor is PWMing at 100%.
    BTW, if either wheel gets lugged down (e.g. from gripping it with your hand), the other one will slow accordingly.
    616 x 413 - 4K
    edited 2010-11-26 16:42
    Ingenious, PhiPi! So the encoders are always on duty behind the scenes to keep the wheels in sync and the bot going straight. Fabulous... now can they also be used to:
    1) specify a certain straight travel distance, and
    2) make calibrated turns?
    This is lookin' good, Friend!
    edited 2010-11-26 17:15
    Erco,
    Yes to both 1) and 2).
  • logan996logan996 Posts: 281
    edited 2010-11-26 19:51
    hey erco also you could use Chris's new servo + hackerport pen lift/lowering hack.
    edited 2010-11-26 20:04
    Take a look at the third post (from Ken) in this thread:
    http://forums.parallax.com/showthread.php?t=127511
