Smelly....could mean trouble.
My power connections: 5.9V on PIN 2 of J1 and GND on PIN 12 of J1. Voltage is coming from a wall outlet plug adapter rated at 5.9V, 375 mA. I was having a problem with my Prop-plug not connecting again and I noticed a funny smell. So I started to very careful feel for any heat off the components on the Spinneret. Heat (noticeable) was coming from the W5100 and that common electronics smell when they are about to burn up. I turned the power off immediately. Is this a concern? I was only running the simple webpage "hello world" code.
Thank You,
Matthew Eckman
Thank You,
Matthew Eckman
http://forums.parallax.com/showthread.php?t=127086
(Maybe the next batch should have some silkscreening on J1.)
Matthew, if you can't return the smell back to the Spinneret we will replace it for you. Everybody should have a positive experience with this product, even if we have some trouble with connections now and then.
Let me know how it works out kgracey@parallax.com (no PM please).
MAJOR CORRECTION ON IMAGES - sorry, I took apart my wires and just hooked them up real quick to take the photo. I have them backwards in the photo I attached. Thankfully I didn't connect power with it like that...phew. I switched it around and it powers on. So from the real photo the red alligator clip is actually ground and the black is actually power, sorry for the confusion.
I haven't been able to figure out my connectivity issues with the computer yet, sometimes it recognizes it and other times it doesn't. I believe I have eliminated the power source being a problem so this just leaves a bad USB cable, a bad Prop-plug, or an intermittent connection on the Spinneret. I am going to further diagnose this problem. Ha, it could just end up being human error.
Thank you, Ken, for being understanding, I will let you know how things turn out.
Matthew Eckman
