Need help capturing a response. — Parallax Forums
electromanjelectromanj Posts: 270
edited 2010-11-12 14:30 in Propeller 1
Hello everyone! I have a question that is probably simple for you, but I don't know where to start.
I am sending commands to a controller and then getting a response. This is my code:
pub send_telegram
  waitcnt(clkfreq/100+cnt)
  debug.str(string("sending telegram",cr))
  waitcnt(clkfreq*2+cnt) 'wait for at least 3.5 character intervals
  plc.tx($01)
  plc.tx($03)
  plc.tx($40)
  plc.tx($9B)
  plc.tx($00)
  plc.tx($02)
  plc.tx($A0)
  plc.tx($24)
  waitcnt(clkfreq*2+cnt)'wait for at least 3.5 character intervals
  GetResponse
Pub GetResponse
  repeat
    rx:=GetDataByte
PUB GetDataByte|Flag,Data,_Rx
    Flag := 0
    repeat while Flag == 0
      Data := plc.rxcheck
      if Data <> -1
         _Rx := Data
         Flag := 1
    Result := _Rx
    debug.tx(34)      'places a " between hex characters so I can tell them apart
    debug.hex(_RX,2)
I am reading the response fine on the parallax serial terminal.
My question is... how would I capture the response and hold it so I can parse it out later as useful data?
Many thanks in advance.
    edited 2010-11-11 21:08
    You can store data on an EEPROM or record it on an SD card. Is that the kind of thing you want to do?
  • electromanjelectromanj Posts: 270
    edited 2010-11-11 21:15
    No sorry I was not very clear. I can read the response from the controller, but I don't know how to "store" the response so I can work with it. Maybey I already am and don't know it? I am completely lost here. I can read the response on the serial terminal, but I would like the propeller to read the response and parse data from the response then perform an action. I hope this makes sense.
    edited 2010-11-11 21:34
    In other projects I've done when I get data from a sensor I store it in a variable and then do something with that variable.
    For instance RC time on a pot. I get the rc time decay and then compare it with a table to decipher where the pot is at.
    With my current program I have figured out how to display the response from the controller on the serial terminal, but I dont know how to capture the response within the program to get info from it so the program can use that data for actions. Mostly because I'm a moron.
    edited 2010-11-11 21:49
    Well, you could store the response in a variable. What does the response look like?
    edited 2010-11-11 22:01
    Hello Mike,
    The resonse is actually similiar to the telegram.
    For instance send: 01 03 40 9B 00 02 A0 24
    recieve: 01 03 3f 00 01 C4 D4 F6
    The response is not exact but that's the format.
    edited 2010-11-11 22:09
    You have not described a format, just given a single example of it. How about describing a pattern or structure of the byte strings?
    Have a look at Extended FullDuplexSerial in the Object Exchange. It's an extension for FullDuplexSerial for receiving character strings terminated by a carriage return, but the same technique can be used for receiving other byte strings of information and processing the bytes to derive something useful.
    edited 2010-11-11 22:21
    The protocol is modbus RTU
    The message would be: 01 03 3F 29 00 02 19 D7
    The response would be: 01 03 04 00 00 00 C4 FB A0
    Message:
    01 -slave address
    03 -read register
    3F, 29 -parameter to be read
    00, 02- 32 bit register
    19 ,D7- CRC
    edited 2010-11-11 22:29
    I'm not 100% clear on this yet, but I think the response goes like this.
    01-slave adress
    03-read register
    04- byte count to follow
    00,00,00,C4- result of the read
    FB,A0- return CRC
  • AribaAriba Posts: 2,697
    edited 2010-11-11 23:51
    You can do something like that to parse the response:
    PUB GetResponse : value | cmd, bcnt, crc
      repeat until plc.rx == $01      'wait for first byte (slave address)
      cmd := plc.rx                   'get command
      bcnt := plc.rx                  'get byte count
      value := 0
      repeat bcnt                     'get value
        value := value << 8 + plc.rx
      crc := plc.rx << 8 + plc.rx     'get crc
    But depending of the number of possible responds and slaves, you might need a more complex parser, and also test if the command is right.
    Andy
    That worked out great! Thank you very much.
    I Appriciate everyone's help!
