program keeps locking up/crashing — Parallax Forums
laser-vectorlaser-vector Posts: 118
edited 2010-11-06 21:33 in Propeller 1
hi all,
im having a little issue where i have started 3 cogs,
two of them drive a stepper motor and are constantly reading their speed variable which is pumped into waitcnt(clkfreq/speed + cnt)
at the same time there is a serial interface (PreambleCommandIndex) that can update these variables via command input and read them back as a status screen (status command "?").
im not sure if im sharing the variables correctly as the two motor driver processes are very high priority and the serial interface is very low.
if im running the motors fast (over 500 steps per second) and i type in the command to read out the variables sometimes it will lock up and do funny things.
the code i have is kind of long, its something i just threw together in the last couple of days so its not very well commented (some comments are incomplete/false) ill fix these soon!, i can explain anything if needed:
CON
  _CLKMODE      = XTAL1 + PLL16X
  _XINFREQ      = 5_000_000
  highpinX       = 19
  lowpinX        = 16
  highpinY       = 23
  lowpinY        = 20
OBJ
  NUM     : "numbers"
  Debug   : "fullduplexserial"
VAR
  Long DirX, DirY
  Long idx, stpIdxX, stpIdxY, stpDelay, stepspeedX, stepspeedY, stepcnt
  Long RXbyte, Data
  Long stack0[70], Stack1[50], Stack2[50]
  Long LimitMaxX, LimitMaxY
  byte Estop
  Long AsciiNumbers
  Long PositionX, PositionY
  Long INDSpeedX, INDSpeedY, INDLimitX, INDLimitY, INDDirectionX, INDDirectionY, INDPosX, INDPosY
PUB main | c
       Num.Init                                ' initilize numbers
       Debug.Start(31, 30, 0, 9600)            ' configure serial communication
       LimitMaxX := INDLimitX := 500
       LimitMaxY := INDLimitY := 500
       DirX := INDDirectionX := 1
       DirY := INDDirectionY := 1
       StepSpeedX := INDSpeedX := -1
       StepSpeedY := INDSpeedY := -1
       PositionX  := INDPosX := 0
       PositionY  := INDPosY := 0
       cognew(PreambleCommandIndex, @Stack0)   ' main loop to compile and distribute value of DataLong
       cognew(StepDriverX, @stack1)
       cognew(StepDriverY, @stack2)
PUB StepDriverX|T
      dira[highpinX..lowpinX]~~
      repeat
        repeat while EStop == False and StepSpeedX => 0
          repeat while StepSpeedX == 0
          if DirX == 1
           StepFwdWaveX
           waitcnt(clkfreq/StepSpeedX + cnt)
          if DirX == 0
           StepRevwaveX
        if stepspeedX == -1
          outa[highpinX..lowpinX]~
PUB StepDriverY|T
      dira[highpinY..lowpinY]~~
      repeat
        repeat while EStop == False and StepSpeedY => 0
          repeat while StepSpeedY == 0
          if DirY == 1
           StepFwdWaveY
           waitcnt(clkfreq/StepSpeedY + cnt)
          if DirY == 0
           StepRevwaveY
       if stepspeedY == -1
         outa[highpinY..lowpinY]~
PUB PreambleCommandIndex | c                   '"c" is to index through the data array, "t" is the loop true/false flag
        Repeat
          DEBUG.RXFLUSH
          WAITCNT(CLKFREQ/1000 + CNT)          ' start Main data acqusition loop, execution is now localized within this loop only
          RXbyte := Debug.RXcheck              ' setting rxbyte to the value in rxcheck's serial buffer
          Case RXbyte
            "O" :
              Debug.Str(String("O"))
              debug.tx($00)
              debug.tx($0d)
              Debug.Str(String("************SYSTEM INFORMATION************"))
              debug.tx($0d)
              debug.tx($0d)
              Debug.Str(String("GLOBAL SETTINGS"))
              debug.tx($0d)
              Debug.Str(String("E Stop Status: "))
              If Estop == 0
                   Debug.Str(String("FALSE"))
              ELSE
                   Debug.Str(String("TRUE"))
              debug.tx($0d)
              debug.tx($0d)
              Debug.Str(String("CHANNEL X SETTINGS"))
              debug.tx($0d)
              Debug.Str(String("Position:             "))
              'Debug.str(num.tostr(INDPosX, num#dec))
              debug.tx($0d)
              Debug.Str(String("Maximum Speed Limit:  "))
              WAITCNT(CLKFREQ/10 + CNT)
              Debug.str(num.tostr(INDLimitX, num#dec))
              Debug.Str(String(" Steps/Second"))
              debug.tx($0d)
              Debug.Str(String("Current Speed Setting:"))
              IF StepSpeedX == -1
                 Debug.Str(String(" DEACTIVATED!"))
              ELSE
                Debug.str(num.tostr(INDSpeedX, num#dec))
              debug.tx($0d)
              Debug.Str(String("Travel Direaction:     "))
              Case DirX
                 1 :
                   Debug.Str(String("Positive"))
                 0 :
                   Debug.Str(String("Negitive"))
               other :
                   Debug.Str(String("N/A"))
              debug.tx($0d)
              debug.tx($0d)
              Debug.Str(String("CHANNEL Y SETTINGS"))
              debug.tx($0d)
              'Debug.str(num.tostr(INDPosY, num#dec))
              debug.tx($0d)
              Debug.str(num.tostr(INDLimitY, num#dec))
              debug.tx($0d)
              IF StepSpeedY == -1
              ELSE
                Debug.str(num.tostr(INDSpeedY, num#dec))
              debug.tx($0d)
              Case DirY
                 1 :
                 0 :
               other :
              repeat 5
               debug.tx($0d)
            "D" :
              Debug.Str(String("D"))
              Repeat
               If RXbyte => 0
                 Case RXbyte
                   "X" :
                     Debug.Str(String("X"))
                     ASCIIToNum(1)
                     INDDirectionX := AsciiNumbers <# 1
                     DirX := AsciiNumbers <# 1
                   "Y" :
                     Debug.Str(String("Y"))
                     ASCIIToNum(1)
                     INDDirectionY := AsciiNumbers <# 1
                     DirY := AsciiNumbers <# 1
                   "Q" :
                  OTHER :
                    Debug.Str(String("!"))
            "L" :
              Debug.Str(String("L"))
              Repeat
               If RXbyte => 0
                 Case RXbyte
                   "X" :
                     ASCIIToNum(4)
                     INDLimitX := AsciiNumbers
                     LimitMaxX := AsciiNumbers
                   "Y" :
                     ASCIIToNum(4)
                     INDLimitY := AsciiNumbers
                     LimitMaxY := AsciiNumbers
                   "Q" :
                  OTHER :
            "G" :
              Debug.Str(String("G"))
              Repeat
                If RXbyte => 0
                  Case RXbyte
                    "X" :
                      ASCIIToNum(10)
                      INDSpeedX := AsciiNumbers <# LimitMaxX
                      StepSpeedX := AsciiNumbers <# LimitMaxX
                    "Y" :
                      ASCIIToNum(10)
                      INDSpeedY := AsciiNumbers <# LimitMaxY
                      StepSpeedY := AsciiNumbers <# LimitMaxY
                    "Q" :
                   OTHER :
            "S" :
              Debug.Str(String("S"))
              Repeat
                If RXbyte => 0
                  Case RXbyte
                    "X" :
                      INDSpeedX := -1
                      StepSpeedX := -1
                    "Y" :
                      INDSpeedY := -1
                      StepSpeedY := -1
                    "Q" :
                   OTHER :
              EStop := True
              INDSpeedX := -1
              StepSpeedX := -1
              INDSpeedY := -1
              StepSpeedY := -1
            "I" :
              Debug.Str(String("I"))
              EStop := False
PUB ASCIIToNum(DecimalCount) | C, N
        AsciiNumbers := 0
        C := 0
        data := 0
        Repeat
          If RXbyte => 0
            case RXbyte
              "0".."9" :
                AsciiNumbers := AsciiNumbers * 10 + (RXbyte - "0")  <# 1_000_000_000
              $0D   :
                c := (DecimalCount - 1)
              "Q" :
             other :
               return
            if c => (DecimalCount - 1)
               return
           C++
PUB FormLong(bytecnt) | C                                 ' constructs an array from incoming serial data
        data := FALSE
        C := 0                                            ' setup, counter reset = 0
        Repeat                                            ' then repeat this part while T flag is true
          RXbyte := Debug.RXcheck                         ' retreive byte from serial buffer
          If RXbyte => 0                                  ' if rxbyte is true there is a byte from the buffer in it, Go Get It!!
             If RXbyte == $0D                             ' if a carriage return was sent
               Repeat C From 0 To (bytecnt - 1) <# 3      ' loop while looking for false bytes in the array
                If Data.byte[C] == -1                     ' if fase byte exsists
                 Data.byte[C] := 0
               Return                                     ' --> Return to caller
             Data.byte[C] := RXbyte                       ' then data[array#] = serial data byte (next pass array# "c" will = + 1 )
             RXbyte := -1                                 ' reset rxbyte to false, go back and loop until rxcheck's buffer passes byte to rxbyte, OR>
             If c == (bytecnt - 1)                        ' if the last long in Data[last-array#] is not false
               Return                                     ' incriment the byte position indxer/counter
           C ++
{--------------------------CHANNEL Y--------------------------}
PRI stepFwdX
  PositionX ++
  INDPosX := PositionX
  stpIdxX := ++stpIdxX // 4                    ' point to next step
  outa[highpinX..lowpinX] := XSteps[stpIdxX]                ' update outputs
PRI stepRevX
  PositionX --
  stpIdxX := (stpIdxX + 3) // 4                ' point to previous step
PRI stepFwdWaveX
  PositionX ++
  outa[highpinX..lowpinX] := XStepsW[stpIdxX]
PRI stepRevWaveX
  PositionX --
PRI HalfStepFwdX
  PositionX ++
  stpIdxX := ++stpIdxX // 8
  outa[highpinX..lowpinX] := XStepsH[stpIdxX]
PRI HalfStepRevX
  PositionX --
  stpIdxX := (stpIdxX + 7) // 8
PRI pauseX(ms) | c
  c := cnt                                   ' sync with system counter
  repeat until (ms-- == 0)                   ' repeat while time left
    waitcnt(c += clkfreq / 1000)             ' wait 1 ms
PRI stepFwdY
  PositionY ++
  INDPosY := PositionY
  stpIdxY := ++stpIdxY // 4                    ' point to next step
  outa[highpinY..lowpinY] := YSteps[stpIdxY]                ' update outputs
PRI stepRevY
  PositionY --
  stpIdxY := (stpIdxY + 3) // 4                ' point to previous step
PRI stepFwdWaveY
  PositionY ++
  outa[highpinY..lowpinY] := YStepsW[stpIdxY]
PRI stepRevWaveY
  PositionY --
PRI HalfStepFwdY
  PositionY ++
  stpIdxY := ++stpIdxY // 8
  outa[highpinY..lowpinY] := YStepsH[stpIdxY]
PRI HalfStepRevY
  PositionY --
  stpIdxY := (stpIdxY + 7) // 8
PRI pauseY(ms) | c
DAT
  XSteps       byte  %0011, %0110, %1100, %1001                               ' full step
  XStepsW      byte  %0001, %0010, %0100, %1000                               ' Wave
  XStepsH      byte  %0001, %0011, %0010, %0110, %0100, %1100, %1000, %1001   ' Half step
  YSteps       byte  %0011, %0110, %1100, %1001                               ' full step
  YStepsW      byte  %0001, %0010, %0100, %1000                               ' Wave
  YStepsH      byte  %0001, %0011, %0010, %0110, %0100, %1100, %1000, %1001   ' Half step
Thanks for any ideas or help!!!!!
    edited 2010-11-06 16:10
    laser-vector,
    My intuition makes me think that the Stack space allocated for PreambleCommandIndex is not large enough.
  • laser-vectorlaser-vector Posts: 118
    edited 2010-11-06 16:23
    That definitely made a huge difference, it used to crash after the 3rd - 5th status update.
    i made Long stack0[250], Stack1[100], Stack2[100]
    and it still crashes but its after like 30 updates!
    thanks for the help so far!!
    is there something im forgetting to clear after a status update?
    edited 2010-11-06 17:13
    Maybe, maybe not. But the reason for these lockups is primarily due to recursion. Worst example is PreambleCommandIndex. From within the case statement you keep calling yourself in a number of locations. That will eventually eat up your stack. You'll have to find a better way of returning to the top of the method.
    laser-vector,
    Making use of QUIT within the PreambleCommandIndex PUB instead of calling PreambleCommandIndex again will help, but it won't solve the case where the ASCIIToNum(DecimalCount) PUB calls PreambleCommandIndex
