Conditional Execution Encoding — Parallax Forums
devin122devin122 Posts: 8
edited 2010-11-11 16:31 in Propeller 1
Im writing a Propeller Emulator, and I was looking for a way to quickly decode the conditional field of the opcode. This is what I have so far using standard c syntax . The conditional bits in the opcode are called x_0 through x_3 where x_0 is the least significant bit. C and Z Should be obvious
A = (x_3 & (C & Z)) | (x_2 & (C & !Z)) | (x_1 & (!C & Z)) | (x_0 & (!C & !Z))
If A is true then the instruction is executed, otherwise it is not. I've checked this over and it should work. Any input? Anyone have any simpler solutions?
  • Nick MuellerNick Mueller Posts: 815
    edited 2010-11-06 15:26
    Did you really want to use the bitwise operators & and |?
    Nick
  • devin122devin122 Posts: 8
    edited 2010-11-06 15:32
    Yup, its all about the speed, Im trying to make the emulator as fast as possible
    edited 2010-11-09 01:19
    Devin122, very useful project! What platforms will it run on?
    edited 2010-11-09 02:10
    Bitwise logical operators don't necessarily make it faster. In bitwise, the complete expression has to be evaluated. In logical, short-cut evaluation is allowed and might be faster.
    Nick
  • AleAle Posts: 2,363
    edited 2010-11-09 06:17
    May be he wants anemulator for another uprocessor like an (X)AVR(32) (it exists already).
  • AribaAriba Posts: 2,697
    edited 2010-11-09 06:47
    If it must be as fast as possible, I would consider a lookup table.
    4 condition bits + Carry + Zero flag = 6 address inputs. The returned value must only be a bit (True/Flase) so only 64 bits are necessary (64 bytes may be faster).
    Andy
    edited 2010-11-09 07:22
    If it must be fast, I'd still start with a clear, readable and most of all working program.
    Then I'd consult the profiler, see where inlining could work and look for bottlenecks.
    Nick
    edited 2010-11-09 08:08
    Nick
    What is more clear and readable? This
    or this
    A := condTab[x<<2 + C<<1 + Z]
    DAT
    condTab byte 0,0,0,0  'if_never
            byte 1,0,1,0  'if_c
            byte 0,1,0,1  'if_z
            byte 1,0,0,0  'if_c_and_z
    Andy
    edited 2010-11-09 08:17
    You could use A = (X >> ((C << 1) | Z)) & 1, where X contains the 4 conditional bits. Or you could use A = (I >> (((C << 1) | Z)) + 18) & 1, where I is the instruction. I believe this will work, but you should test it to make sure.
    edited 2010-11-09 08:21
    or this
    Code:
    DAT
    byte 1,0,1,0 'if_c
    byte 0,1,0,1 'if_z
    This:
    A = x || C || Z;
    Nick
    edited 2010-11-09 08:29
    This:
    A = x || C || Z;
    Nick
    That doesn't give the correct results.
    edited 2010-11-09 08:54
    Ah! I was confused by the 64 (2^6) entries the "short and clear" table should have had but didn't.
    Nick
    edited 2010-11-09 09:07
    But that:
    (x_3 && (C && Z)) || (x_2 && (C && !Z)) || (x_1 && (!C && Z)) || (x_0 && (!C && !Z))
    should be:
    (x_3 && C && Z) || (x_2 && C && !Z) || (X_1 && !C && Z) || (x_0 && !C && !Z)
    further simplified:
    (((x_3 && Z) || (x_2 && !Z)) && C) || (((X_1 && Z) || X_0 & !Z)) && !C)
    This can be speed up:
    if (C)
    A = (x_3 && Z) || (x_2 && !Z);
    else
    A = (X_1 && Z) || X_0 & !Z);
    Nick
    edited 2010-11-09 09:21
    Yes, that will work (with some slight syntax corrections). However, I believe A = (X >> ((C << 1) | Z)) & 1 would be faster on most processors. Your solution uses logical ORs, ANDs and NOTs, which compile to test and jumps.
    edited 2010-11-10 00:15
    That's a valid assumption. Hopefully, he doesn't use TRUE and FALSE to set the operands. That's why I prefer the logical operators (not knowing what other shortcuts the OP took to "make it fast").
    First, a program has to be readable and maintainable. After that, you can comment out the initial algorithm and replace it with hard to read code if one prefers.
    Nick
    edited 2010-11-10 00:54
    devin122 wrote: »
    To add some fun, any instruction becomes a nop when the next instruction is being fetched from address 0 (and no, it's not limited to location $1FF).
    I feel so embarrassed. What I meant to say is that the PC must be at $1FF while the instruction is executed. While this means that the next fetch could come from #0 (but could theoretically come from anywhere else) the reverse isn't true as any jmp #0 will fetch from #0.
  • mparkmpark Posts: 1,336
    edited 2010-11-10 03:30
    kuroneko wrote: »
    SRSLY? That's kooky.
    How do you arrange it so an arbitrary instruction is followed by one fetched from 0?
    edited 2010-11-10 05:47
    mpark wrote: »
    DAT
                    movi    ctra, #%0_11111_000
                    neg     frqa, increment
                    mov     phsa, preset
                    jmp     phsa                    ' jump to preset + [COLOR="Red"]2[/COLOR]*frqa = target
                                                    ' jump target is written [COLOR="Red"]one[/COLOR] cycle later
                    ...                             ' i.e. PC = preset + [COLOR="Red"]3[/COLOR]*frqa = -1
    target          rdlong  cnt, #0                 ' nop, [COLOR="Red"]cog thinks it's at $1FF (-1)[/COLOR],
                                                    ' execution continues at 0
    increment       long    target+1
    preset          long    target*3+2
    edited 2010-11-10 07:48
    kuroneko,
    Exactly how many undocumented features does that code use? :) Is there a document that documents undocumented features?
    Dave
    edited 2010-11-10 16:12
    Dave Hein wrote: »
    If you ask me then I'd say one (undocumented feature). Which is the abort behaviour. I figure it's to do with the hand-over sequence for a coginit just before it executes user code. Anyway, I keep collecting stuff like this in the Propeller Tricks & Traps thread.
    edited 2010-11-10 23:52
    kuroneko wrote: »
    DAT
                    neg     frqa, increment
                    mov     phsa, preset
    Kuroneko, you are kurazy!
    What about jmp #0? Where's the next instruction fetched from in that case?
    edited 2010-11-10 23:59
    mpark wrote: »
    I don't quite follow. If it's just a jmp #0 then the next fetch is from #1. Can you elaborate?
    In case you refer to a phase jump $000:$000A then the first target is indeed #0 (2+2*(-1)) but as the PC is $1FF (2+3*(-1)) at this point it becomes a nop and is then executed again for real.
    A preset 2, increment = 1 (frqx = -1)
    edited 2010-11-11 11:17
    I guess I'm not understanding what "next instruction" means. Say jmp #0 lives at address 10; what is the next instruction? I was thinking it would be whatever is at address 0. I'm not seeing why you say the next fetch is from 1.
    edited 2010-11-11 13:56
    Include me in the confused group. What's a phased jump? Does it have to do with pipeline, such as with a JNZ where the target address is prefetched rather than the next address? So a jmp #0 is a NOP, or is the instruction at $1ff a NOP? Please explain using small words. :)
    I have the strong feeling that this goes OT so I stop here and move the explanation to a different thread ([post=953138]singularity[/post]).
    Just for clarification, the fetch-from-0 isn't enough and in fact irrelevant. The cog must think it's at $1FF (which would normally lead to a fetch from #0). Apologies for the confusion.
