Cooking Timer Project
Hello Im trying to make a cooking timer following the information
in this instructables site i have program the pic and power it up ever time
i do so i just get a blank screen on my lCD any help will be great Thank You.
I also did a flip the switch to test mode to test the lcd and it works just fine
im not sure what switch go what way i have try all the off and ons it showed me.
Thank you,
http://www.instructables.com/id/Cooking-Timer/?ALLSTEPS
Thank you,
'* Name : Time Countdown *
'* Author : Arava *
'* Date : 4/24/2007 *
'* Version : 1.0 *
'* Notes : PIC16F819 *
'BUZZER CONNECTED TO PortB.4
'START BUTTON CONNECTED TO PortB.5
'RESET BUTTON CONNECTED TO PortB.0
'FOOD BUTTONS CONNECTED TO Ports B.1/ B.2 / B.3
'TIMER BUTTON CONNECTED TO PortA.2
'LCD CONNECTED TO PortB.6
'POTENTIOMETER CONNECTED TO PortA.0
OSCCON = %01100100 'set the internal oscillator to 4MHz
TRISA = %11111111 'make portA all input
ADCON1 = %10001110 'make portA.0 analog , all others Digital
output portB.6 ' output to lcd
OUTPUT portB.4 ' output to buzzer
input portB.5 ' input start button
input portB.0 ' input reset button
input portB.1 ' chicken button input
input portB.2 ' meat button input
input portB.3 ' egg button input
include "modedefs.bas"
DEFINE ADC_BITS 10 ' 10 bit adc conversion
DEFINE ADC_CLOCK 3 'These difine ADCIN parameters
DEFINE ADC_SAMPLEUS 20
'******************** variables***********************
counting var bit ' 0=not counting. 1=counting in progress.
secCount var word ' counting the seconds wile cooking
secLoop60 var word
secRemain var word ' the time for the countdown
minRemain var word
TimeLoop var byte
cookingTime var word ' the time that takes for the food to cook
DeBounce con 10
start_buttonState var bit 'start button
reset_buttonState var bit
c_buttonstate var bit
m_buttonstate var bit
e_buttonstate var bit
timer_buttonstate var bit
weight var byte ' between 1-8 pounds
PotNoise con 2 'potentiometer noise
PotSignal var word 'potentiometer signal (0-1012)
PotSignala var word
LCD var PortB.6
BUZZER var PortB.4
chic_button var portB.1
meat_button var portB.2
egg_button var portB.3
start_button var portB.5
reset_button var portB.0
timer_button Var portA.2
'***************************setup*************************************
Setup:
PAUSE 100
serout2 LCD,396,[12] 'clear LCD screen
pause 10
serout2 LCD,396,[17] 'turn on the LCD backlight
pause 10
serout2 LCD,396,["select food type"] ' prints first instruction
PAUSE 500 ' wait for LCD to initiate
counting = 0
cookingTime = 0
secCount = 0
secRemain = 0
minRemain = 0
TimeLoop = 0
low BUZZER
Goto main
'***************************main*************************************
' if counting - keep counting.
' if not - feel for food buttons, if it's not pressed don't do anything.
' any other button pressed now - nothing happens
Main:
if counting = 1 then ' if cooking
Goto Timer ' keep counting
endif
c_buttonstate = chic_button ' feelFoodButton - feel 4 buttons
m_buttonstate = meat_button
e_buttonstate = egg_button
timer_buttonstate = timer_button
if c_buttonstate = 1 then 'if chick button changes ****
pause 10 'debounce time
c_buttonstate = chic_button 'feel the button
if c_buttonstate = 1 then 'if the input is real
serout2 LCD,396,[12] 'clear LCD screen for countdown
pause 5
serout2 LCD,396,["chicken", 13, "weight:"]
pause 5
Goto CalculateChicken
endif
endif
if m_buttonstate = 1 then 'if meat button changes ****
m_buttonstate = meat_button 'feel the button
if m_buttonstate = 1 then 'if the input is real
pause 5
serout2 LCD,396,["meat", 13, "weight:"]
pause 5
Goto CalculateMeat
endif
endif
if e_buttonstate = 1 then 'if egg button changes ****
e_buttonstate = egg_button 'feel the button
if e_buttonstate = 1 then 'if the input is real
pause 5
serout2 LCD,396,["egg", 13, "level: "]
pause 5
Goto CalculateEgg
endif
endif
if timer_buttonstate = 1 then 'if timer button changes ****
timer_buttonstate = timer_button 'feel the button
if timer_buttonstate = 1 then 'if the input is real
pause 5
serout2 LCD,396,["timer"]
pause 5
Goto CalculateTimer
endif
endif
gosub FeelResetButton
Goto main
'***************************CalculateTimer cooking time*************************************
CalculateTimer:
'feel potentiometer + calculate var weight
adcin 0,PotSignal 'take two readings and compare them
pause 10 'with Noise as a measure
adcin 0,PotSignala 'a simple way to clean up your singnal
if PotSignala < PotSignal - PotNoise then
cookingTime = (PotSignala/4)*60
serout2 LCD,396,[148,"Time: ", dec cookingTime /60 ,"min"] 'courser to second line pos 0 print weight.
endif
if PotSignala > PotSignal + PotNoise then
endif
'***special Feel Start Button timer time
start_buttonState = start_button
if start_buttonState = 1 then 'if egg button changes ****
start_buttonState = start_button 'feel the button
if start_buttonState = 1 then 'if the input is real
pause 5
serout2 LCD,396,[148, "Time "] 'courser to line1 position 0
pause 5
counting = 1 'change to counting state
goto Timer 'and start counting
endif
endif
Goto CalculateTimer
'***************************CalculateMeat cooking time*************************************
CalculateMeat:
weight = PotSignala/126
serout2 LCD,396,[156, dec weight , "p "] 'courser to second line pos 8 print weight.
endif
endif
if weight < 2 then
cookingTime = 35*60
else
cookingTime = (45+((weight-2)*10))*60
endif
gosub FeelStartButton 'go to FeelStartButton
Goto CalculateMeat
'***************************CalculateChicken cooking time*************************************
CalculateChicken:
endif
endif
if weight < 2 then
cookingTime = 40*60
else
cookingTime = (60+((weight-2)*10))*60
endif
'***************************CalculateEgg cooking time*************************************
CalculateEgg:
if weight <=4 then
serout2 LCD,396,[156, "soft"] 'courser to second line pos 8 print weight.
else
serout2 LCD,396,[156, "hard"]
endif
endif
if weight <=4 then
else
endif
endif
if weight <=4 then
cookingTime = 5*60
else
cookingTime = 11*60
endif
'special FeelStartButton for egg state
pause 5
if weight <=4 then
serout2 LCD,396,[134, "soft"] ' courser to line0 position 6
else
serout2 LCD,396,[134, "hard"]
endif
pause 5
endif
endif
Goto CalculateEgg
'***************************Feel Start Button*************************************
FeelStartButton:
pause 5
serout2 LCD,396,[137, dec weight, "p "] 'courser to line0 position 9
pause 5
endif
endif
return
'***************************Feel Reset Button*************************************
'feel reset button
FeelResetButton:
'reset_buttonState = reset_button
' if reset_buttonState = 1 then 'if egg button changes ****
' pause 5 'debounce time
reset_buttonState = reset_button 'feel the button
if reset_buttonState = 1 then 'if the input is real
low BUZZER
' pause 5
goto setup 'and start counting
endif
'endif
return
'**********************************timer********************************************
Timer:
secLoop60 = 0
while secLoop60 <= 59
TimeLoop = 0
while TimeLoop <= 99 'counts 100 times
TimeLoop = TimeLoop +1 ' 1 miliSec
pause 10
wend
secCount = secCount +1 ' add one sec to count
secRemain = cookingTime - secCount ' calculates the time remains to cook
minRemain = secRemain/60
if secLoop60 = 0 then
serout2 LCD,396,[155,dec minRemain,":00"]
else
if secLoop60 > 50 then
serout2 LCD,396,[155,dec minRemain,":0", dec 60-secLoop60]
else
serout2 LCD,396,[155,dec minRemain,":", dec 60-secLoop60]
endif
endif
secLoop60 = secLoop60 + 1
if secCount = 900 then ' after 15 min
high buzzer ' buzz 5 sec
pause 5000
secCount = secCount - 5 ' reduce 5 sec from count
low buzzer
endif
if secCount = cookingTime then ' if the food is ready
while 1=1
HIGH BUZZER ' make noise with BUZZER
pause 5000
low BUZZER
wend
counting = 0 ' change counting to off
goto Setup ' go back to start
endif
wend
goto Timer
Jim
you may be need to be over here with your question:
http://www.picbasic.co.uk/forum/forum.php
