Cooking Timer Project — Parallax Forums
esmoreesmore Posts: 1
edited 2010-11-04 19:57 in Robotics
Hello Im trying to make a cooking timer following the information
in this instructables site i have program the pic and power it up ever time
i do so i just get a blank screen on my lCD any help will be great Thank You.
I also did a flip the switch to test mode to test the lcd and it works just fine
im not sure what switch go what way i have try all the off and ons it showed me.
Thank you,
http://www.instructables.com/id/Cooking-Timer/?ALLSTEPS
'*  Name    : Time Countdown                                    *
'*  Author  : Arava                                             *
'*  Date    : 4/24/2007                                         *
'*  Version : 1.0                                               *
'*  Notes   : PIC16F819                                         *
'BUZZER CONNECTED TO PortB.4
'START BUTTON CONNECTED TO PortB.5
'RESET BUTTON CONNECTED TO PortB.0
'FOOD BUTTONS CONNECTED TO Ports B.1/ B.2 / B.3
'TIMER BUTTON CONNECTED TO PortA.2
'LCD CONNECTED TO PortB.6
'POTENTIOMETER CONNECTED TO PortA.0
OSCCON = %01100100    'set the internal oscillator to 4MHz
TRISA = %11111111     'make portA all input
ADCON1 = %10001110    'make portA.0 analog , all others Digital
output portB.6      ' output to lcd
OUTPUT portB.4      ' output to buzzer
input portB.5       ' input start button
input portB.0       ' input reset button
input portB.1       ' chicken button input
input portB.2       ' meat button input
input portB.3       ' egg button input
include "modedefs.bas"
DEFINE ADC_BITS 10          ' 10 bit adc conversion
DEFINE ADC_CLOCK 3          'These difine ADCIN parameters
DEFINE ADC_SAMPLEUS 20
'******************** variables***********************
counting var bit      ' 0=not counting. 1=counting in progress.
secCount var word     ' counting the seconds wile cooking
secLoop60 var word
secRemain var word   ' the time for the countdown
minRemain var word
TimeLoop var byte
cookingTime  var word  ' the time that takes for the food to cook
DeBounce con 10
start_buttonState var bit         'start button
reset_buttonState var bit
c_buttonstate var bit
m_buttonstate var bit
e_buttonstate var bit
timer_buttonstate var bit
weight var byte                  ' between 1-8 pounds
PotNoise con 2                    'potentiometer noise
PotSignal var word                   'potentiometer signal (0-1012)
PotSignala var word
LCD var PortB.6
BUZZER var PortB.4
chic_button var portB.1
meat_button var portB.2
egg_button var portB.3
start_button var portB.5
reset_button var portB.0
timer_button Var portA.2
'***************************setup*************************************
Setup:
    PAUSE 100
    serout2 LCD,396,[12]            'clear LCD screen
    pause 10
    serout2 LCD,396,[17]                  'turn on the LCD backlight
    pause 10
    serout2 LCD,396,["select food type"]  ' prints first instruction
    PAUSE 500                             ' wait for LCD to initiate
    counting = 0
    cookingTime  = 0
    secCount = 0
    secRemain = 0
    minRemain = 0
    TimeLoop = 0
    low BUZZER
Goto main
'***************************main*************************************
' if counting - keep counting.
' if not - feel for food buttons, if it's not pressed don't do anything.
' any other button pressed now - nothing happens
Main:
    if counting = 1 then       ' if cooking
        Goto Timer             ' keep counting
    endif
    c_buttonstate = chic_button  ' feelFoodButton - feel 4 buttons
    m_buttonstate = meat_button
    e_buttonstate = egg_button
    timer_buttonstate = timer_button
    if c_buttonstate = 1 then                      'if chick button changes ****
            pause 10                               'debounce time
            c_buttonstate = chic_button            'feel the button
            if c_buttonstate = 1 then              'if the input is real
                    serout2 LCD,396,[12]           'clear LCD screen for countdown
                    pause 5
                    serout2 LCD,396,["chicken", 13, "weight:"]
                    pause 5
                    Goto CalculateChicken
            endif
    endif
    if m_buttonstate = 1 then                      'if meat button changes ****
            m_buttonstate = meat_button            'feel the button
            if m_buttonstate = 1 then              'if the input is real
                    pause 5
                    serout2 LCD,396,["meat", 13, "weight:"]
                    pause 5
                    Goto CalculateMeat
            endif
    endif
    if e_buttonstate = 1 then                      'if egg button changes ****
            e_buttonstate = egg_button            'feel the button
            if e_buttonstate = 1 then              'if the input is real
                    pause 5
                    serout2 LCD,396,["egg", 13, "level:  "]
                    pause 5
                    Goto CalculateEgg
            endif
    endif
    if timer_buttonstate = 1 then                  'if timer button changes ****
            timer_buttonstate = timer_button       'feel the button
            if timer_buttonstate = 1 then          'if the input is real
                    pause 5
                    serout2 LCD,396,["timer"]
                    pause 5
                    Goto CalculateTimer
            endif
    endif
    gosub FeelResetButton
Goto main
'***************************CalculateTimer cooking time*************************************
CalculateTimer:
    'feel potentiometer + calculate var weight
    adcin 0,PotSignal                       'take two readings and compare them
    pause 10                                'with Noise as a measure
    adcin 0,PotSignala                      'a simple way to clean up your singnal
    if PotSignala < PotSignal - PotNoise then
        cookingTime = (PotSignala/4)*60
        serout2 LCD,396,[148,"Time: ", dec cookingTime /60 ,"min"]  'courser to second line pos 0 print weight.
    endif
    if PotSignala > PotSignal + PotNoise then
    endif
    '***special Feel Start Button timer time
    start_buttonState =  start_button
    if start_buttonState = 1 then                      'if egg button changes ****
            start_buttonState = start_button           'feel the button
            if start_buttonState = 1 then              'if the input is real
               pause 5
               serout2 LCD,396,[148, "Time          "]     'courser to line1 position 0
               pause 5
               counting = 1                     'change to counting state
               goto Timer                       'and start counting
            endif
    endif
Goto CalculateTimer
'***************************CalculateMeat cooking time*************************************
CalculateMeat:
        weight = PotSignala/126
        serout2 LCD,396,[156, dec weight , "p  "]  'courser to second line pos 8 print weight.
    endif
    endif
    if weight < 2 then
        cookingTime = 35*60
    else
        cookingTime = (45+((weight-2)*10))*60
    endif
    gosub FeelStartButton                         'go to FeelStartButton
Goto CalculateMeat
'***************************CalculateChicken cooking time*************************************
CalculateChicken:
    endif
    endif
    if weight < 2 then
        cookingTime = 40*60
    else
        cookingTime = (60+((weight-2)*10))*60
    endif
'***************************CalculateEgg cooking time*************************************
CalculateEgg:
        if weight <=4 then
            serout2 LCD,396,[156, "soft"]  'courser to second line pos 8 print weight.
        else
            serout2 LCD,396,[156, "hard"]
        endif
    endif
        if weight <=4 then
        else
        endif
    endif
    if weight <=4 then
       cookingTime  = 5*60
    else
       cookingTime = 11*60
    endif
    'special FeelStartButton for egg state
               pause 5
               if weight <=4 then
                    serout2 LCD,396,[134, "soft"]  ' courser to line0 position 6
                else
                    serout2 LCD,396,[134, "hard"]
                endif
                pause 5
            endif
    endif
Goto CalculateEgg
'***************************Feel Start Button*************************************
FeelStartButton:
               pause 5
               serout2 LCD,396,[137, dec weight, "p  "] 'courser to line0 position 9
               pause 5
            endif
    endif
return
'***************************Feel Reset Button*************************************
 'feel reset button
FeelResetButton:
    'reset_buttonState =  reset_button
   ' if reset_buttonState = 1 then                      'if egg button changes ****
         '   pause 5                                   'debounce time
            reset_buttonState = reset_button           'feel the button
            if reset_buttonState = 1 then              'if the input is real
               low BUZZER
             '  pause 5
               goto setup                       'and start counting
            endif
    'endif
return
'**********************************timer********************************************
Timer:
    secLoop60 = 0
    while secLoop60 <= 59
        TimeLoop = 0
        while TimeLoop <= 99                'counts 100 times
            TimeLoop = TimeLoop +1          ' 1 miliSec
            pause 10
        wend
        secCount = secCount +1                        ' add one sec to count
        secRemain = cookingTime - secCount            ' calculates the time remains to cook
        minRemain = secRemain/60
        if secLoop60 = 0 then
            serout2 LCD,396,[155,dec minRemain,":00"]
        else
            if  secLoop60 > 50 then
                serout2 LCD,396,[155,dec minRemain,":0", dec 60-secLoop60]
            else
                serout2 LCD,396,[155,dec minRemain,":", dec 60-secLoop60]
            endif
        endif
        secLoop60 = secLoop60 + 1
        if secCount = 900 then               ' after 15 min
            high buzzer                      ' buzz 5 sec
            pause 5000
            secCount = secCount - 5         ' reduce 5 sec from count
            low buzzer
        endif
        if secCount = cookingTime  then     ' if the food is ready
            while 1=1
                HIGH BUZZER                      ' make noise with BUZZER
                pause 5000
                low BUZZER
            wend
            counting = 0                    ' change counting to off
            goto Setup                      ' go back to start
        endif
    wend
goto Timer
  • hover1hover1 Posts: 1,929
    edited 2010-11-04 17:01
    You might be in the wrong forum. This is a forum for Parallax products. There is no support for PIC's. here.
    Jim
    esmore wrote: »
    Thank you,
    esmore,
    you may be need to be over here with your question:
    http://www.picbasic.co.uk/forum/forum.php
