Need help with 16x1 LCD — Parallax Forums
hinvhinv Posts: 1,272
edited 2010-11-04 17:45 in Propeller 1
Hi,
I am having trouble with getting my LCD module to display anything. I can write to it, and read it back, but I am unable to see anything on the display. I used Jon Williams article for the circuit here [url] http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp2.pdf [/url]
If somebody knows what I am doing wrong to not get anything, even a cursor, on the screen, I would surely appreciate advice. BTW, I did try turning the pot back and forth.
Doug
con
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
obj
  lcd  : "jm_lcd4_ez"
  ser   : "FullDuplexSerial"
PUB Start | okay, inbyte
  ''Test Parallax Serial Terminal number entry and display.
  ser.start(31, 30, 0, 9600)
  ''Start up lcd
  ser.Str(String("initing lcd, "))
  okay := lcd.init(0, 16, 1)
  if okay
    ser.Str(String("inited ok, "))
  ser.Str(String("display on, "))
  lcd.display(1)
  lcd.cursor(2)
  ser.Str(String("scrolling nuts, "))
  lcd.scrollstr(1, 1, 8, 250, @nuts)
  ser.Str(String(" repeat loop", 13))
  inbyte := lcd.in
  ser.Dec(inbyte)
  ser.tx(inbyte)
  lcd.moveto(4,1)
  inbyte := lcd.in
  ser.Dec(inbyte)
  ser.tx(inbyte)
  lcd.moveto(1,1)
  inbyte := lcd.in
  ser.Dec(inbyte)
  ser.tx(inbyte)
  ser.tx(13)
  repeat
dat
nuts            byte    "AbCdEfGhIjKlMnOp", 0
volts           byte    "   VOLTS        ", 0
  • LeonLeon Posts: 7,620
    edited 2010-11-04 08:23
    Many LCDs work OK at 5V with the contrast pin grounded, but some need a negative supply on it. If it's powered from 3.3V, it will definitely need a negative supply. You could generate a negative supply from an output with, say, 1 kHz on it, and a voltage doubler using a couple of diodes and capacitors.
  • hinvhinv Posts: 1,272
    edited 2010-11-04 10:35
    Thanks Leon,
    You aren't correct, but you pointed me to relook at my circuit, and I found out that I forgot to wire the wiper on my pot. It now works!
    This is the second time I wired it up on my demo board. Could it be that I wired it wrong twice?
    Oh well, all is good now!
    Doug
  • BRBR Posts: 92
    I really like Jon's LCD driver, but hooking one of these 4-bit LCD displays up to a breadboard and getting all the connections right is a hassle...which is the reason I wrote this lcd emulator object:
    http://obex.parallax.com/objects/643/
