How to desolder Panasonic ECG surface mount caps?
Caps like this...
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PCE3878TR-ND
I have a hot air rework station but I can't seem to get these hot enough to desolder without messing up the pad on the PCB as I'm pulling them up. I can get one side free at a time...but not both sides simeltaneously. What's the trick? Do I need a different tip for my air station? My standard tip is 1/4" round tip. But I also have a square tip that I use for desoldering the propeller (forget what size that tip is).
I initially solder big stuff like this by doing the fry-pan method.
Thanks.
Thanks.
BUT for De soldering use a normal Iron and go back and forth between the 2 leads . 1 2 1 2 1 2 every other second . and use some LEAD solder ( if RoHS is not needed ) and it will drop the melt temp of the Lead free solder found On most new boards . Chip Quik is a MUCH better dropper but its not like you can get it at a the gas station .
If you add solder it can increce the thermal mass of each lead to the point where it can" hold" a Melted temp long enough to remove the component . still 1 2 1 2 1 2 is needed . but its easy up to 8 Pins or so .
