Sticky Situation — Parallax Forums
Sticky Situation
BumpBump Posts: 592
edited 2010-10-29 07:06 in Propeller 1
The Sticky Situation of the Propeller Chip forum has been addressed.
We merged the HYDRA forum into here and as a result... mucho sticky!
So this little post, which will sink to the bottom of these forums in time, is a quick update of where the recently stuck threads can now be found.
Propeller Q&A Sticky, it can now be found on the Propeller: Getting Sta... Index under the 'Getting Started' category.
The HYDRA Projects Master List is also located on the main Index sticky, linked above, under the 'Extra' category.
Similarly the 2009/10 Propeller Contest Results are also found under 'Extra', and if you haven't seen the results yet... I highly recommend it.
The Book Project for the HYDRA - Seeking Authors was dropped off the sticky board, and is now floating in the forums.
Less of a sticky situation, more space for new threads to appear. Hooray!
    edited 2010-10-28 17:25
    Thanks, Bump! We all appreciate your quick and effective action!
    edited 2010-10-28 18:21
    You will now notice some pretty active forum management from Bump. Bump has worked at Parallax from high school, through college and now well-beyond. He's got the keys to manage forums, the right vibe, and the knowledge to pull it all together. He's working to configure vBulletin 4.0 alongside of some forum rearrangement.
    I am particularly appreciative of Bump's ability and drive.
    Oh, and this guy is every bit as zany as he appears from a distance. Truly creative, whacky, technical and articulate at the same time.
    This should have been made a Sticky itself.
    There is simply too much good information here which will soon be buried.
    Common guys, there is room for "one more sticky" :)
    OBC
