Sticky Situation
The Sticky Situation of the Propeller Chip forum has been addressed.
We merged the HYDRA forum into here and as a result... mucho sticky!
So this little post, which will sink to the bottom of these forums in time, is a quick update of where the recently stuck threads can now be found.
Propeller Q&A Sticky, it can now be found on the Propeller: Getting Sta... Index under the 'Getting Started' category.
The HYDRA Projects Master List is also located on the main Index sticky, linked above, under the 'Extra' category.
Similarly the 2009/10 Propeller Contest Results are also found under 'Extra', and if you haven't seen the results yet... I highly recommend it.
The Book Project for the HYDRA - Seeking Authors was dropped off the sticky board, and is now floating in the forums.
Less of a sticky situation, more space for new threads to appear. Hooray!
I am particularly appreciative of Bump's ability and drive.
Oh, and this guy is every bit as zany as he appears from a distance. Truly creative, whacky, technical and articulate at the same time.
There is simply too much good information here which will soon be buried.
Common guys, there is room for "one more sticky"
OBC
