Servo Controller - jittery with high servo counts
I have the servo controller board and some custom s/w to drive the servos. All is well when I have 4 servos hooked up. Once I get to 8, I start getting some noise going to the servos. At 12 servos, it's a lot of noise and the servo response is no longer workable.
I have walwart with selectable voltage as the supply. Is it possible that it doesn't have enough amperage? If so, I'm considering using a scavenged PC power supply to apply 7V. Or am I likely looking at another issue?
Steve
Steve
Use the +5V off of that supply rather than taking the difference... Although you may get 7V, they usually aren't meant to operate like that.
At +5V you'll take a little bit of a power (speed) hit, but you should have plenty of current.
Are you using the old Servo Controller:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/346/Default.aspx
or the new one:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/595/Default.aspx
Also, are you using Analog or digital servos?
Jim
@hover1: I have an old board (non-propeller) and a new. I'm using the old one because the propeller-based board would always give me jittery servos, even with only one connected. (as soon as I applied power, they'd start twitching) The servos are all Futaba S3003 - I assume those are analog...?
On the Propeller based servo controller, place a 1K resistor in line with the servo signal, and that should take care of the jitters.
Jim
Cool - that should help with the inevitable expansion next year.
http://forums.parallax.com/showthread.php?t=118121
I just put a 1K resistor pack on all pins now.
Jim
