Any interest in Propeller Platform USB bare PCB's?
When I ordered PCB's for the Propeller Platform USB, the board house mistakenly sent me de-panelized boards. They fixed the error and re-sent panels, but I now have 300 Propeller Platform USB bare boards.
Before I add them to my pile of 'junk boards', does anyone want them? Some details;
If anyone is interested, I'll also put together little 2-page SMT assembly guide that would include part numbers and tips. Of course, you'll need to provide the parts.
Bare boards are already available for the original Propeller Platform, and that's 100% through hole. This would be for folks who want an SMT project or prefer the smaller footprint. microSD & USB are nice, too.
Any interest? Here's the populated board;
Edit: They're available along with an assembly guide here
- Surface Mount Soldering: Prop QFP, D-pak vregs, microSD. If you put them together by hand, I would skip the FTDI and USB parts, they're a pain. The microSD card is pretty easy. Discrete SMD parts are 0805 or larger.
- Through Hole: Power jack, switch, caps, crystal, and pin sockets.
- Board size is 2.8" x 2.5".
- Price would be $7.
De-panelize just means to break apart the panel. So instead of a short, wide stack of panels, I got a tall, narrow stack of individual boards. It's not a problem if you were to assemble the board by hand, but it's a no-go for the assembly company.
I am waiting for the SDRAM boards to be available, as well...
I'd like a couple.
I'm surprised so many of us are still afraid of surface mount. After reading an online tutorial, I now think I prefer surface mount (as long as it has leads I can see). I've started using amost all smt resistors and capacitors since they save so much space. The 0603 size fits nicely between proto board holes.
Any chance on making a kit with the parts that go on the board?
Duane Degn
For me, discrete SMD's are easier than through holes - it takes the same amount of time and you don't have to clip off the leads. Some of the small pitch IC's are a pain, though. You just need better equipment to do those.
I'm interested if you have any left.
I normally make my own single sided SMT boards (draft in a well known free web tool, print to a JPEG, flip in MSPAINT, Laser print on Press-n-Peel blue, iron (the house iron) on board, etch in Amonium Perasulphate bath, wash, populate and solder using my 15W iron). Works well for the QFP Prop and FT232RL, etc, and is mostly reliable (occasional track doesn't come out and needs Canar wire). Very time consuming and have a number of failures. To increase reliability I was going to get them professionally made.
Though on a CBA, your's are a lot cheeper! They look nice and quite functional :-) Having some professionally made boards may reduce some reliability problems.
Please let me know how I can order some. I'm in Australia, so postage/postage preferences to manage the cost would be a factor.
This is a lot easier (and less time consuming) than making your own board. They're also electrically tested, and the design is very flexible, so you can use it many of your Prop projects.
oops I see you already offer them via your website, nice.
Looks like the price is $7.00 (+Shipping?) (First Post, I missed it too the first time)
Nick,
I would be interested in a few. You say the USB and FDTI chip are a pain but I see the USB connector to be troublesome, but not out of the realm of hand soldering. Agree?
Jim
Would these for say work?
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=A32370-ND
@Hover - The 2 painful parts are the USB jack and the FTDI chip. I can do the FTDI with my elenco, but it takes patience and some wick. The USB jack has very short leads, I can do it, but I need to use the needle nose tip and a magnifying glass. Sometimes I mess it up, though.
Just bought everything needed to make 2
Thanks!
Where are these listed/mentioned/shown?
Dr Acula has a great deal on great bare boards. But sometimes I need accommodations for a mezzanine board. That seems to be a feature of your boards.
Adding your own expansion modules is definitely the point. You can use any protoboard, jumper to a breadboard, or design your own pcb. Templates for designing your own (for Eagle, Diptrace, or ExpressPCB) are here.
Nick,
I'll have to admit I spent a while trying to find the bare board. It's not really apparent.
I would put it up as a "related item" or have a link to the bare board in the parts list, (link the picture to the bare board)
Just a thought.
Jim
I also really enjoy the videos you have posted on your site they are very informative, im coming form the SX, and the prop has always been intimidating to me, but the videos simplify the basics, keep those coming!!!
Tracking says they left CA on Nov 1st. I hope they get here this weekend. I can't wait to put them together!
But I left my tweezers at work...NOOOoo!
I would like to purchase 1 set of bare pcb, microSD holder, power switch, dc socket, reset button, ftdi chip, 5v regulator, 3.3v regulator and usb socket.
How much would the total cost be plus shipping by regular airmail to Malaysia?
William Chan
I accidentally bought the wrong package resistor array and forgot to get a terminal block for one of them.
I found the FTDI chip easy to solder with just the solder that was already on the board. Tack down one pin, line up the others and press down on all the pins with the iron. A good tacky flux helps.
The hardest parts for me were the voltage regs. I ended up tacking down both legs with the chip at an angle up off the board. Then got some solder on the iron tip and put it in between the chips ground tab and the board and as the solder soaked under I pressed the chip down to the board.
Good deal!
Nice to see the USB portion went together without a hitch. Still need to get my boards on order.
Jim
Could you post your Bill Of Material from Digikey or Mouser for all the parts you ordered to populate these boards?
http://www.gadgetgangster.com/working_files/ggppusb/SMT_soldering.pdf
AT24C512BN-SH25-TCT-ND____ IC EEPROM 512KBIT 1MHZ 8SOIC_______________2
RNCS0805BKE1K50CT-ND_______RES 1/10W 1.5K OHM .1% 0805________________2
CRT0805-BY-1002ELFCT-ND____RES 10K OHM 1/8W .1% 0805 SMD______________4
P4.7KZCT-ND________________RES 4.7K OHM 1/8W .1% 0805 SMD_____________2
445-1351-1-ND______________CAP CER .10UF 25V X7R 10% 0805______________10
478-1280-1-ND______________CAP CERM 22PF 5% 100V NP0 0805_____________10
587-2254-1-ND______________CAP CERM 4.7UF 35V Y5V 1206_________________2
497-1496-1-ND______________IC REG LDO 1.5A 3.3V DPAK____________________2
497-3468-1-ND______________IC REG LDO 5.0V 1.5A D-PAK___________________2
350-2046-1-ND______________LED INGAN BLU WATER CLR 0805 SMD____________2
401-1769-1-ND______________SWITCH TACT SILVR 300GF GULLWING___________2
HR1941CT-ND_______________CONN MICRO SD R/A PUSH-PULL SMD_____________2
768-1007-1-ND______________IC USB TO SERIAL UART 28-SSOP _______________2
MMBT2222ATPMSCT-ND_______TRANSISTOR NPN GP 40V SOT23________________2
H11671CT-ND_______________CONN RCPT USB MINI B R/A SMD_________________2
450-1599-ND________________SWITCH SLIDE 2POS R/A BLACK T/H_____________2
XC1711-ND_________________CRYSTAL 5.000 MHZ 18PF 49US_________________2
CP-102B-ND________________CONN POWER JACK 2.5MM PCB CIRC______________2
ED6302-ND_________________CONN SOCKET STRIP 02PIN .100 STR_____________2
ACASA-10K/10K-2CT-ND______RES ARRAY 10K/10K OHM 4RES SMD______________2
This list does not include the Terminal block, the three 47uF 25v electrolytic caps, or the pin sockets/headers (2x 16 position, 2x 4 position)!!
http://www.gadgetgangster.com/find-a-project/56.html?projectnum=297
http://www.gadgetgangster.com/find-a-project/56.html?projectnum=301
For the parts list, there's a slightly better BOM you can download it off Parallax's page for the Propeller Platform in the 'Open Source downloads' section here.
I had less of a problem with the Vreg - I soldered the tab first by adding solder to the bare pad, putting the vreg on top and heating up the tab with my iron. It worked for me, but you do get the vreg pretty hot. ymmv.
Yeah that's what I was trying to avoid. I only had enough parts to get it right the first time!
Parallax's BOM direct link
http://www.parallax.com/Portals/0/Downloads/docs/prod/osi/32208PropellerPlatformOSIFiles.zip
