Propeller 2 Preliminary Feature List
I do believe this is relevant to your interests:
http://www.parallax.com/Propeller2FeatureList/tabid/898/Default.aspx
Enjoy!
Enjoy!
That's Kilo Bytes.
It says "Optional external 32-bit addressable SDRAM for run-time data workspace; code space is not extendable"
I say, pah!. Zog is going to love running megabytes of C code from that external RAM. As is Catalina and Java and whatever other systems there are cooking.
ADC's DAC's comparators oh my!
and 1.28 BIPS! crazzzy !
I need to hurry up and figure out how to program the Prop 1 so I can jump to the Prop 2!
And we all want more details on the SDRAM support
Prop2 is in dvanced stage of design so many specs might have changed, right?
Sorry as I need say that.
I'm surprised BUT not directly in positive way.
It is to many questions still not answered.
Actually, this is the clearest picture we have. This document was written last week after talking with Chip and Jeff directly.
What questions do you still have Sapieha?
Also, a small change was made if you've already checked/downloaded the .pdf
Under 'General: ... Planned 128-Pin Package(1)'
Now reads 'General: ... Planned 128-Pin SMT Package (1)'
In entire description it is no any WORD about Input speed possibility.
1. --->
As I mentioned from start I tested first Propeller I it is nice to have relatively fast Output speeds on PIN's but if it is not track by same speed on INPUT pin's side ---> It is waste of silicon.
Same question track to Counters.
2. ---> Serialiser
3. ---> Strobed IO's with Read/Write signaling
4. ---> Extra MEM in COG's that can be used in that way Chip described and other ways we can FIND of theirs usage.
AND more
1. SDDRAM and SD card - hardware or software I/O?
2. 100 I/O pins! How are they controlled? (Must be more complex than DIRx/OUTx/INx.)
3. What are the dedicate 8 pins used for during boot? (SPI, serial & SD?)
4. Heck, details on everything on the right side.
Perfect!!! I had hoped, but reality is far better!
Are they gone?
How they will actually do it, I don't know, but that is the simplest, and it would make code more backward compatible.
Yay Bump! Looks great!
Thanks to all @Parallax for providing such a list way in advance of having silicon in OUR grubby hands. Wonder how many other companies have done such an early release?
I and others sure were hoping for such a view.
No sense in using SDRAM if there isn't R/W signaling. If Prop2 were just like Prop1 in this regard, they wouldn't have mentioned external RAM at all.
Did that get cut ?
Bean
Seems to me, the net product of that will be faster Spin programs, but not as small of ones as we get now.
BTW: Looks pretty sweet to me! It's all going to be a very nice boost over Prop I. Can't wait. ...err, well I can, but don't want to.
This is a good point. I don't believe that Prop II will have a bus as such for any particular memory technology. Rather it will offer hardware assistance for creating such buses with a little software help.
In which case the feature on offer is not really "SDRAM support" but rather a bunch of features in the I/O system that can help with such devices.
We want to know more....
I do hope there is some high speed serial I/O possibilities, serializer/deserializer, that can be used to enable fast communication with external devices and other Prop II's
Please keep us updated, and I will try one of these Prop II once it is out!
YES ---> But will that R/W signaling be possible to handle standard 8-Bits wide I/O IC's.
As You maybe know to THAT needs some control of wait time for that signals. Else it will be no much usable
I am a little disappointed with 128KB Hub RAM and 32KB Hub ROM. This will mean basically no new ROM code space so I expect we will lose some of the existing ROM code and this may mean sometimes the old ROM code will now have to use RAM space.
OTOH only 128 KB HUB RAM
