Syncing Cogs After Launch — Parallax Forums
pjvpjv Posts: 1,903
edited 2010-10-23 09:47 in Propeller 1
Hi All;
What is the best (short and simple) scheme to synchronize cogs after they are launched?
I wish to have all cogs run assembly code, and a stub in spin gets them all going. Then I need to have them all synchronized so that instructions in all of them execute on the same system clock edge.
It appears that as each cog is launched, it can take on one of four clock positions. Now, to synchronize them right after launch, typically one would hold them off with a "waitcnt" set to trigger some point in the future. What good and clever code schemes have been developed to effect this?
Or is there some better way, perhaps with locks or some other concept (I don't want to mess with pins and "waitpeq").
Thanks for any ideas.
Cheers,
Peter (pjv)
  • ericballericball Posts: 774
    edited 2010-10-22 11:35
    The normal method is to save a CNT value and then have all cogs WAITCNT for that value.
    Just remember that any HUB accesses will nudge the cogs out of sync.
  • pjvpjv Posts: 1,903
    edited 2010-10-22 11:51
    Hi Eric;
    Well, thank you, but can you offer any particalar clever short piece of code to determine what count is sufficiently into the future, yet not waiting a whole 53 seconds for the system counter to wrap?
    Cheers,
    Peter (pjv)
    edited 2010-10-22 11:57
    IIRC when I did my multi-cog video driver I did it empirically. So after the WAITCNT have the cog do something (i.e. light an LED at pin+COGID). Then do a binary search to narrow down the minimum value. Or just use something high enough to work and then tune it later.
    edited 2010-10-22 12:05
    I could not help reading the thread title as "Sinking COGs after lunch"
    http://www.realbeerbox.com/Bottle-COG-321.asp
    Anyway,PJV, why worry so hard. Just read CNT, add a second or two on to it to get a time in the future. Then start your COGs passing them that future time as a parameter.
    When everything is working, if one second bothers you start to reduce it until something breaks.
    Relax, have a COG:)
    edited 2010-10-22 12:32
    Heater;
    That will not work beause the Cogs all launch (not lunch) at slightly different times, so adding a (common) value to each of them prior to the "waitcnt" leaves them as unsynchronized as they were at launch.
    And I would like to release all as quickly as possible.
    What I am now doing is:
    mov Var,cnt
    shr Var,#16 'get rid of insignificant timing ticks
    add Var,#2 'make it a bit bigger (must be larger than 1 ?)
    shl Var,#16 'restore gross magnitude
    waitcnt Var,#0 'wait for sync
    And this seems to work, but the shift magnitude needs to be big enough to see the 'future' for all Cogs.
    But I was looking for something clever with locks, or simpler.
    Cheers,
    Peter (pjv)
  • pgbpsupgbpsu Posts: 460
    edited 2010-10-22 13:13
    Hi pjv-
    I think Heater had something like this in mind:
    PUB MAIN |  start_time
        start_time  := ( clkfreq / 2 + cnt )                 ' cnt value everyone should use
        cog1 := cognew(@cog1_code,@start_time)               'Launch new cog
        cog2 := cognew(@cog2_code,@start_time)               'Launch new cog
    DAT
    cog1_code
                  rdlong    cog1_start, par
                  waitcnt   cog1_start, #100           ' wait here until start_time
                  synchronized code goes here
    cog1_start  long 0
    DAT
    cog2_code
                  rdlong    cog2_start, par
                  waitcnt   cog2_start, #100           ' wait here until start_time
    cog2_start  long 0
  • K2K2 Posts: 695
    edited 2010-10-22 13:31
    Heater, where the ad says that COG has a pleasing happy character, are they referring to you?
    Oh, wait, I may have misread that.
    edited 2010-10-22 13:35
    PJV,
    What could be simpler? Don't foregt that CNT is globally available to all COGs, they all see the same value at the same time.
    In your main spin code:
    1) Read the CNT value.
    2) Add a second or two on to it to get a time in the future.
    3) Start your COGs, passing them that future time as a parameter through PAR.
    Yes they all launch at slightly different times, but we don't care because...In your COG PASM code:
    1) Read that future time value from PAR (or somewhere it points to)
    2) Waitcnt for that future time.
    3) Do you synched code.
    I think pgbpsu's code is heading in that direction. That code may need some "ORG 0" statements at the start of each PASM section
    edited 2010-10-22 13:41
    Having said all that I have to admit I have never tried this.
    Given that PASM instructions take four clocks can we be sure that after the waitcnt that hey all start in step or is there a possibility of a 1, 2 or 3 clock difference? I would hope not but with doing the experiment I may never believe it.
    K2, I don't think I've ever had the pleasure of that kind of COG. Wonder if they could deliver some to Finland?
    edited 2010-10-22 14:31
    OK, thanks guys.
    Use a number that all can get from Hub Ram!....... DUH!
    Obviously I'm too focused on assembler .... I was trying for each Cog to independently figure out its own, and you have pointed me to an obvious answer. Although my method appears to work, yours is simpler. Thanks
    Cheers,
    Peter (pjv)
    edited 2010-10-22 14:43
    Let us know how you get on. As I said I have never actually done this.
    edited 2010-10-22 16:28
    Heater / pgbpsu;
    I just tested it, and it works perfectly.
    So thanks to you both. One of these days I will start using Spin.
    Cheers,
    Peter (pjv)
    edited 2010-10-22 23:54
    pjv,
    Great stuff.
    Do you have the possibility to measure how closely synched he slave COGs are? Say by having the slave COGs toggle different pins and check the timing between edges with a scope or LSA.
    edited 2010-10-23 09:29
    Hi Heater;
    Yes, fortunately my tools will get down to picoseconds, but I only own one low-cap (1.5 pf) active probe because they cost about $2K each, so I cannot do a pin to pin comparison with that. But the regular scope probes are good for a nano second or two, and I can extrapolate when running multiple identical probes. The 16 channel parallel probe yields an uncertainty of 2 nano sec.
    All said, there is about a 0.8-ish nano second transit delay from one cog's output to the next as the out state is passed along the OR chain.
    Very early on in my propeller experiments (years ago) I chatted with Chip about this, and he confirmed that, and if I recall correctly, he stated there was a reversal in the chain sequence, half way along.
    I can have closer look at this for you if you want.
    Cheers,
    Peter (pjv)
    pjv,
    Wow, I would have been happy with a result to within a clock period or so. Glad to hear it works so well.
