Simple LED Circuit
NWCCTV
I need to accomplish the following using the absolute minimum of parts. Will be using low watt (1.2-3.3V) LED. I want to be able to light an LED when a magnet makes contact with a piece of metal.
http://en.wikipedia.org/wiki/Capacitive_sensing
Also there are pressure sensors sold at the Parallax store. And a reed switch which activates when a magnet is nearby. See the sensors area here...
http://www.parallax.com/Store/tabid/60/Default.aspx
Maybe if the led/magnet consisted of two magnets insulated from each other. Ground wire from battery to one and led ground wire to the other. The metal object might complete the circuit.
Not even a Stamp, USB adapter, solar cell, shift register, or relay?
You mean like a magnet and a switch???
Sheesh. That's hardcore.
