Simple LED Circuit — Parallax Forums
Simple LED Circuit
NWCCTVNWCCTV Posts: 3,629
edited 2010-10-17 20:38 in General Discussion
I need to accomplish the following using the absolute minimum of parts. Will be using low watt (1.2-3.3V) LED. I want to be able to light an LED when a magnet makes contact with a piece of metal.
  • bill190bill190 Posts: 769
    edited 2010-10-17 00:18
    Perhaps a Capacitive Sensor would work? Here is info on that...
    http://en.wikipedia.org/wiki/Capacitive_sensing
    Also there are pressure sensors sold at the Parallax store. And a reed switch which activates when a magnet is nearby. See the sensors area here...
    http://www.parallax.com/Store/tabid/60/Default.aspx
  • LeonLeon Posts: 7,620
    edited 2010-10-17 02:44
    If the magnet makes contact, it could simply complete a circuit. No additional components required!
  • RagtopRagtop Posts: 406
    edited 2010-10-17 06:50
    I think they want the light on when attached to any metal object and off when unattached with the battery attached to led/magnet.
    Maybe if the led/magnet consisted of two magnets insulated from each other. Ground wire from battery to one and led ground wire to the other. The metal object might complete the circuit.
    edited 2010-10-17 11:02
    The metal object might be painted, though. Anyway NWCCTV needs to clarify where the magnet and piece of metal are relative to the circuit containing the light.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2010-10-17 11:55
    The magnet would be on a flat surface. A ball will contain the LED and when the ball contacts the magnetic surface the LED will light. Thanks for the posts. I think I have a starting point now. Oh, and Ragtops theory is correct.
  • ercoerco Posts: 20,260
    edited 2010-10-17 14:06
    So no HiFi, WiFi, 4G, Hotspot, iPhone, Bluetooth, Quadcore, Propeller, Blackfin, AVR, PIC, Arduino, dongle, or GPS cross-referenced to a database of every metal object known to man?
    Not even a Stamp, USB adapter, solar cell, shift register, or relay?
    You mean like a magnet and a switch???
    Sheesh. That's hardcore.
    edited 2010-10-17 19:51
    Yep, Like a magnet and a switch. Small, cheap and simple!!!!!
    edited 2010-10-17 20:13
    Sounds like a reed switch is what you are looking for.
    I'm still confused about where the magnet is. So let me see if I understand: you have a ball (steel?) with a battery, an LED, and some sort of switching device. This gets stuck on a magnetic surface. Or is the magnet in the ball, and the ball sticks to any steel or iron surface, e.g. refrigerator door? A drawing would certainly help.
