Simple math question
I keep getting 0 when I do this math equation (an example value of Leading1toLeading2EdgeTime is 54382720)
rpml1tol2 := ((1/((Leading1toLeading2EdgeTime/clkfreq) * 36)) * 60)
final value should be 2.451759186251319046442203209647 or rounded to 2
Does anyone have a code example of how to do that? Am I missing something with float here?
By my calculator with your value (54382720) the answer is 0.6 and change which will be rounded to zero.
Looking at your equation it works on a calculator because you're dealing with fractional values -- you're going to have to rearrange the formula to work within decimal division constraints.
Thanks for the reply ... is there no way to work with a value less than 1?
I searched for over an hour on the forum before posting, trying to find an example that would apply to what I'm doing and I was unable to make anything work.
I believe I would include Float32 in the obj section, how would I insert the references/calls to it in my code though?
Assuming a clkfreq of 80,000,000 the constants evaluate to 133,333,333.333
Now the formual is 133,333,333/Leading1toLeading2EdgeTime which equals 2 in integer math.
If you need more precision use 13,333,333,300/Leading1toLeading2EdgeTime which equals 245 in units of 1/100th.
John Abshier
(clkfreq * 5)/(Leading1toLeading2EdgeTime * 3)
This will truncate to the nearest integer value. If you want to round you will need to use the following:
((clkfreq * 5) + (Leading1toLeadin2EdgeTime *3 / 2))/(Leading1toLeading2EdgeTime * 3)
Dave
... and the answer is 2. Changing to:
... gives 245 which provides additional resolution, though one will have to experiment with the full range of possible values to prevent any rollover/rollunder problems. You could do this to keep 1/100ths resolution and extend the possible range of le1tole2:
Should I heed this as a warning to learn more about floating point math and the propeller, or is there always a simple work around like this?
with 31 digits to the right of the decimal point. That is fine if you just want to display the result, but a second method computes it as a fixed point number that you can use in followup calculations,
24517592
with implied 7 digits rounded off to the right of the decimal point.
The core of the algorithm is simple long division:
result := y / x ' this is the integer part, left of the decimal point repeat ix from 1 to n ' kick out digits to right of decimal point y := y // x * 10 result := (result*10) + (y /x) ' shift digits left and accumulatewhere the first step is the integer part of the result and the loop shifts in n digits to the right of the decimal point.I'll have to try this, this weekend. I would really like to get floats working in my program, as it is becoming apparent I will need them.
