communication between main program and cog help needed
Hello Propellerheads:)
I've started working with the propeller a view days back and am comming along quite nice.
I'm coding an video overlay together based on the HITT video overlay. I'm displaying video on my pal display when there is a video scoure present and when there is not, the propeller generates the signal this all works very good.
My problem is I can't seem to understand how i can feed information from the video overlay object back to my main program. I have tried several options but none of them seem to work.
I hope one of you sees what I'm doing wrong.
Here are the two important objects that I use:
The Main program:
And the Overlay code:
So what i do is add the two lines
to the main routine and than in the main loop i write the variable to the main ram with this line
Am i right to believe that that should be enough to read the _overlayMode value stored in cargo in the main program?
The mainprogram als should convert the _overlayMode value (which is a long right?) to a string value so i can display it on screen with the graphics method "text"
i hope i made myself clear so you understand:) and that someone has the time to take a look at the giant wall of code:P
Thanks in advance!
The Main program:
CON _CLKMODE = XTAL1 + PLL8X _XINFREQ = 10_000_000 x_tiles = 16 y_tiles = 12 VAR long PAL_Mode long bitmap[3072] long display[3072] long cargo long strCargo OBJ overlay : "HITT_Video_Overlay_018" gr : "Graphics" Clock : "Clock_mini" num : "Simple_Numbers" PUB HhDd overlay.start(@PAL_mode) gr.start gr.setup(x_tiles, y_tiles, 0, 0, @display) gr.textmode(1,1,6,0) Clock.Init(_XINFREQ) ' set up clock for accuate 10/second Clock.SetClock(_CLKMODE) ' video update rate Clock.MarkSync repeat ' loop until death gr.colorwidth(1, 0) ' Set Color and Width gr.clear gr.text(50,50,conf) 'This should put the value of the overlaymode on the screen gr.finish gr.copy(@bitmap) Clock.WaitSyncMSec(100) PUB conf strCargo := num.dec(cargo) return strCargo
VAR
LONG cog ' Video cog number (used to stop cog)
PUB Start(VideoActive_PalMode_Screen)
' Start overlay COG
cog:=CogNew(@OverlayAsm, VideoActive_PalMode_Screen)
PUB Stop
if cog
cogstop(cog~ - 1)
DAT
ORG
OverlayAsm MOV _videoActiveAddr, par
MOV _videoActiveValue,#0
WRLONG _palModeValue, _palModeAddr
MOV _palModeAddr,par
ADD _palModeAddr,#4
RDLONG _palModeValue,_palModeAddr
MOV _screenAddr,par ' Get address of screen memory
ADD _screenAddr,#8
'This is my custom line of assembler<<<<------------------
MOV _cargoAddr,par ' Get address of cargo
ADD _cargoAddr,#12
' Setup cnta to use video hardware
MOVI ctra,#%000001_111 ' Video PLL x16
MOV frqa,VideoFreq ' Set video freq to 128MHz (80MHz / 10) = 8MHz * 16 = 128MHz
' Setup VSU (initially off)
MOVI vcfg,#%0_00_0_0_0_000 ' Generation off
MOVS vcfg,#%0000_1100 ' Use pin P18,P19 (2&3 of group 2) for output
MOVD vcfg,#2 ' Use pin group 2 (P16-P23)
MOV vscl,VideoScale ' Setup dot clock to 5.818182 MHz
' Setup I/O pins
ANDN dira,_syncPinMask ' Make Sync Pin an Input
OR dira,_videoPinMask ' Make video Pin an Output
ANDN dira,_genPinsMask ' Make gen Pins an Inputs
MOV _overlayMode,#1 ' 1 = Gen Mode
JMP #GenMode
OvrMain ' Main overlay generation loop
WRLONG _overlayMode, _cargoAddr
' Set video active value
WRLONG _videoActiveValue,_videoActiveAddr
' Wait for sync pin to go high, or timeout waiting
MOV _timeCnt,SyncTimeoutValue
WaitSyncHigh AND _syncPinMask,ina WZ, NR
IF_Z DJNZ _timeCnt,#WaitSyncHigh
IF_Z MOV _overlayMode,#1 ' Timed-out, switch to generate mode
IF_Z JMP #GenMode
WAITPNE _syncPinMask,_syncPinMask ' Wait for Sync pin to go low
MOV _timeCnt,#480 ' Wait 6uSec @ 80MHz
ADD _timeCnt,cnt
WAITCNT _timeCnt,#0
' If sync is STILL low then we are in VSYNC
AND _syncPinMask,ina WZ, NR ' Is Sync Pin still low ?
IF_Z RDLONG _palModeValue,_palModeAddr
IF_Z CMP _lineCnt,#200 WC
IF_Z_AND_C JMP #DontCheckPal
IF_Z CMP _lineCnt,#287 WC
IF_Z_AND_NC MOV _palModeValue,#1
IF_Z_AND_C MOV _palModeValue,#0
IF_Z WRLONG _palModeValue,_palModeAddr
DontCheckPal
IF_Z MOV _lineCnt,#0 ' Yes, reset line counter
IF_Z MOV _currentAddr,_screenAddr ' Yes, reset current address
IF_Z JMP #OvrMain ' Yes, go back to main loop
ADD _lineCnt,#1 ' Adjust line counter
' If we are not on a visable part of the screen, just go back and wait
CMP _palModeValue,#0 WZ
IF_Z CMP _lineCnt,#40 WC ' Don't draw until line 40 NTSC
IF_NZ CMP _lineCnt,#65 WC
IF_C MOV _videoActiveValue,#0
IF_C JMP #OvrMain
IF_Z CMP _lineCnt,#232 WC ' Don't draw after line 232 NTSC
IF_NZ CMP _lineCnt,#257 WC
IF_NC MOV _videoActiveValue,#0
IF_NC JMP #OvrMain
MOV _timeCnt,#230 ' Wait for left margin
ADD _timeCnt,cnt
WAITCNT _timeCnt,#0
' Set video active to 1
MOV _videoActiveValue,#1
MOVI vcfg,#%0_01_1_0_0_000 ' Enable video hardware for VGA generation
ANDN outa,_videoSinkPin ' Allow Sink pin to darken image
MOV _horzCnt,#16 ' Draw 16 longs per line (16*16 = 256 pixels per line)
:NextPattern
RDLONG _dotPattern, _currentAddr ' Get dot pattern from global RAM
XOR _dotPattern,FlipBlackBit ' Flip black bit so that 0=Transparent
ADD _currentAddr,Next_Col ' Adjust current address to next LONG
WAITVID VideoColorsOverlay,_dotPattern ' Send dot pattern to video hardware
DJNZ _horzCnt,#:NextPattern ' Do next dot pattern
SUB _currentAddr,Next_Line
WAITVID videoColorsOvrBlank,#0 ' Clear video hardware
OR outa,_videoSinkPin ' Don't allow Sink pin to darken image
MOVI vcfg,#%0_00_0_0_0_000 ' Disable video hardware
JMP #OvrMain ' Go back to main loop
GenMode
MOVS vcfg,#%0000_0001 ' Use only pin P16 (pin 0 of group 2) for video output
ANDN dira,_videoPinMask ' Make video Pin an Input
OR dira,_genPinsMask ' Make gen sync Pins Outputs
ANDN outa,_genPinsMask ' Make both pins low
MOV _lineCnt,#0 ' 0-2 = VSync; 3-41=TopBlank; 42-233=Image, 234-261=BottomBlank
MOV _overlayMode,#1 ' If bit1 = 1, then first time through
' Purge video hardware
WAITVID videoColorsGen,#0 ' Clear video hardware
MOV _lineTimerCnt,cnt ' Get initial cnt value
GenMain
MOV _videoActiveValue,#0 ' Assume not generating video
CMP _lineCnt,#3 WC ' Are we in VSync ?
IF_C JMP #GenVSync ' Yes, jump
IF_Z CMP _lineCnt,#42 WC ' Are we in TopBlank ? NTSC
IF_NZ CMP _lineCnt,#67 WC
IF_C JMP #GenBlankLine ' Yes, jump
IF_Z CMP _lineCnt,#234 WC ' Are we in Image ? NTSC
IF_NZ CMP _lineCnt,#259 WC
IF_C JMP #GenActiveLine ' Yes, jump
JMP #GenBlankLine ' We must be in BottomBlank
GenVSync
ANDN outa,_genPinSyncMask ' Make gen sync pin low (sync level output)
JMP #GenDone ' Done for this line
GenBlankLine
ANDN outa,_genPinSyncMask ' Make gen pin low (sync level output)
MOV _timeCnt,#376 ' Delay 4.7uSec @ 80MHz
ADD _timeCnt,cnt
WAITCNT _timeCnt, #0
OR outa,_genPinSyncMask ' Make gen pin high (black level output)
MOV _currentAddr,_screenAddr ' Reset current screen address
GenActiveLine
ADD _timeCnt,cnt
WAITCNT _timeCnt,#0
MOV _timeCnt,#430 ' Wait 3uSec @ 80MHz (Left margin)
ADD _timeCnt,cnt
WAITCNT _timeCnt,#0
:NextPattern
WAITVID VideoColorsGen,_dotPattern ' Send dot pattern to video hardware
AND _syncPinMask,ina WZ, NR ' Is Sync input low ?
IF_Z MOV _overlayMode,#0 ' If Sync input is low video input detected, switch to overlay mode
GenDone
ADD _lineCnt,#1 ' Advance line count
IF_Z CMP _lineCnt,#262 WZ ' If _lineCnt reaches 262, then reset it to zero NTSC
IF_NZ CMP _lineCnt,#312 WZ
ADD _lineTimerCnt,LineTimerValue ' Wait for next video line
' Set video active variable
WAITCNT _lineTimerCnt, #0
TJNZ _overlayMode,#GenMain
ANDN dira,_genPinsMask ' Otherwise switch to overlay mode, make gen sync Pin an Input
JMP #OvrMain ' Jump to overlay code
' Constants for OverlayAsm
VideoFreq LONG $1999_9999 ' = 8 Mhz FROM 80Mhz clock x 16PLL = 128MHz
VideoScale LONG $16_160 ' Pixel clock = 128MHz / 22 = 5.818181MHz
VideoColorsOverlay LONG $0C_04_08_00 ' Modify if not using pins 18 & 19 for output
VideoColorsOvrBlank LONG $04_04_04_04 ' Overlay value for blank video
VideoColorsGen LONG $01_00_01_00 ' Modify if not usine pin 16 for output during generation
LineTimerValue LONG 5120 ' 64uSec @ 80MHz
SyncTimeOutValue LONG 1_600_000 ' ~1/10 second
Next_Col LONG 768 ' Offset from one column to the next
Next_Line LONG 16*768-4 ' Offset from line to the next (get subtracted)
FlipBlackBit LONG $AAAA_AAAA ' XOR mask to make 0=transparent
_syncPinMask LONG %0000_0000_1000_0000_0000_0000_0000_0000 ' Sync output from EL1883 IC P23 (22)
_videoPinMask LONG %0000_0000_0000_1100_0000_0000_0000_0000 ' Video output from propeller (~470Ohm) P18,P196yhn 2
_videoSinkPin LONG %0000_0000_0000_0100_0000_0000_0000_0000 ' Video Sink (darken) pin mask P18
_genPinsMask LONG %0000_0000_0000_0011_0000_0000_0000_0000 ' Mask for both generation pins P16,P17
_genPinSyncMask LONG %0000_0000_0000_0010_0000_0000_0000_0000 ' Mask for generation sync pin P17
_overlayMode RES 1 ' 0=Overlay mode; 1=Generate mode
_screenAddr RES 1 ' Address of screen array [8x192] longs
_currentAddr RES 1 ' Address of current array element being drawn
_dotPattern RES 1 ' Dot pattern of current element being drawn
_videoActiveAddr RES 1 ' Address of video active variable in COG memory
_videoActiveValue RES 1 ' 0=Video blanked; 1=Video active
_palModeAddr RES 1 ' Address of PAL_Mode variable
_palModeValue RES 1 ' Hold value in PAL_Mode variable 0=NTSC; 1=PAL generation
_lineTimerCnt RES 1 ' Holds cnt value to start next line when generating
_timeCnt RES 1 ' Used with WAITCNT to make delays
_lineCnt RES 1 ' Current line of screen
_horzCnt RES 1 ' Current long of current line
_cargoAddr RES 1
MOV _cargoAddr,par ' Get address of cargo ADD _cargoAddr,#12
Thanks in advance!
The memory location _cargoAddr is being calculated incorrectly. A multiple of #12 just feels wrong so I looked further.
The complier directive "RES" counts spaces as Longs so remember you add 1 for bytes, 2 for words and 4 for longs when calculating address locations. Below VideoFreq you also have 10 other LONGs defined then you have "cog" at the VAR section. Something is just not right. That #12 should be something more like 24 x 4 = 98dec
Would be a good exercise to create a 'GetAddress' PUB that hands off the address of _cargoAddr during runtime using the @_cargoAddr syntax.
When working with video displays, I will occasionally create a text line to show me where I am at runtime.
Jim-
