UPEW 2010 - thanks OBC, chip, ken, beau, chris, everyone + Expo & PropII observ - Page 2 — Parallax Forums
2»
    edited 2010-10-04 12:43
    Thanks Chris - I *WILL* look and link to your episode on your site... I've been finishing the BOM for PropCade so I can start selling it :)
    I forgot to follow up and mention that the video was completed some time ago and is available on my website. I'm interested in hearing if the video was informational/useful to anyone. Bill, I hope the video helps you sell some product. Take care.
    Savage Circuits TV Episode 8: Bill Henning at the 2010 UPEW
    edited 2010-10-04 15:00
    Bill,
    Thanks. I could use the redirect, however, in all fairness if you want to embed the video (in a more permanent form) you can go directly to the video itself at the link below on my YouTube channel. You should be able to get a direct embedding link. Take care.
    Savage Circuits Episode 8 on YouTube
    edited 2010-10-04 17:41
    Kaoskidd, yes, I am working on a complete write up of the demo that I did at UPEW. I have been really swamped lately so I am behind. Here's a super-short overview:
    Tools:
    • tin-lead, no-clean solder paste
    • 6 mil stainless steel stencil
    • plastic "putty knife" as the squeegee
    • ESD mat as the screening surface
    • alcohol wipes for cleanup
    • divided parts bin for components
    • tweezers for placement of parts
    • $40 "heating element" style (not IR) toaster oven (think it's a Magic Chef)
    • Small metal "cookie sheet" to place boards on
    • oven mitt
    • Candy thermometer
    • Fluke 377 with thermocouple
    Process:
    • Apply paste to stencil
    • lay PCb on ESD mat
    • lay stencil over PCB and align (visually)
    • using putty knife, spread the bead of paste across the PCB apertures using enough pressure so that almost no paste is left across the surface. (ensures that paste is forced into the apertures, but also that the putty knife does not scoop into the aperture)
    • lift stencil up slowly, if the board sticks, tap the stencil to drop it off.
    • check paste print
    • use tweezers to place parts onto paste; give each a slight push to "stick" into the paste.
    • place boards on metal tray into room temp toaster oven
    • set toaster oven to 350+ and turn on
    • monitor temp of candy thermometer/thermocouple while watching for paste to reflow.
    • once paste reflows, leave oven on for about 20 seconds
    • turn off oven, wait 15 seconds
    • open oven door, wait 1 minute
    • pull tray from oven and set away from oven (away from heat)
    • once at room temp remove from tray
    • check for shorts on input and both outputs
    • test by applying 9 volt in and checking for 5.0 +/-0.1 on 5v output and 3.3 +/- 0.1 on 3.3v output
    • place into ESD bag with DC jack and 6 header pins
    • apply 1x3 product label on ESD bag
    • sell a lot and retire.........
    That's how it all works. (well, I am still working on that final step)
  • KaosKiddKaosKidd Posts: 296
    edited 2010-10-14 11:07
    Tools:
    • oven mitt
    • Candy thermometer
    Process:
    • check paste print
    Sweet...
    I'm going to try this once I get to that point. My manual soldering skills leave LOTS to be asked for...
