3000 Farad Capacitor — Parallax Forums
ercoerco Posts: 20,263
edited 2010-10-03 16:13 in General Discussion
What will YOU do with such a cap? http://www.goldmine-elec-products.com/prodinfo.asp?number=G17930
Get two for $40: $25 each, and there's a $10 off coupon for orders $50 or more:
http://www.goldmine-elec-products.com/prodinfo.asp?number=OCT%2410OFF
    edited 2010-09-30 23:30
    They're great for when you need to store and release large amounts of energy quickly. But as a long-term power source, their meager (given their large size) 1100 mAh capacity and high self-discharge rate render them inferior to batteries. Plus, as capacitors, they don't have a flat voltage-vs-time discharge curve.
  • lardomlardom Posts: 1,659
    edited 2010-10-01 07:08
    Several years back I tried to find large caps because I wanted to build a DIY capacitive discharge welder to make my own battery packs. I did not know how to find a supplier at the time. I still have the link for the instructions but since that time I became a Propellerhead.
  • logan996logan996 Posts: 281
    edited 2010-10-01 13:17
    oooooo hehehe yay! someone's gonna have a whole lotta fun making a big shocking thing!
    edited 2010-10-01 18:47
    as much as I really want those caps to play with i should not :(
  • william chanwilliam chan Posts: 1,326
    edited 2010-10-02 02:27
    Phil,
    How do you calculate mAH from Farads?
    A little tidbit from the datasheet, see the info below, the highlight is from the 3000 farad. And even better, it has a short- circuit rating of 9,300 amps. If you don't know what you are doing with these, you might want to think again before purchasing any.
    They also have a one million cycle life, these could be near the end.
    719 x 120 - 25K
