Boe Bot — Parallax Forums
Boe Bot
karthikcegkarthikceg Posts: 4
edited 2010-09-28 10:24 in Robotics
Hello!!!!
Using Boe Bot is it possible to record a given path and retrace it.?.....And also if possible will it be able to avoid a obstacle in its path and will be able to get on its course?:confused:
    edited 2010-09-28 07:39
    Not easily!
  • karthikcegkarthikceg Posts: 4
    edited 2010-09-28 07:52
    Sir i want to do a project on autonomous ground vehicle.(on a small scale)........ I do not know from where to start and how to go about it.
    I want my bot to go on nearly between rough and a smooth surface.I am really worried about my project.
    I just want a little guidance on how to start and how i should equip myself before starting it.
    edited 2010-09-28 08:46
    Sounds like you're just starting out and you may lack a firm grasp of how difficult it is to achieve what you want. That makes it hard to tell you where to start. You need to do some legwork investigating autonomous navigation, dead reckoning, odometry, detecting obstacles, collision avoidance, path planning, etc.
    That said, I designed & built a cheap, simple, accurate robot that you could teach a path by driving it and have it follow it automatically after that. It only looked at wheel rotations to measure distance and turns. No obstacle or collision sensors. That's a reasonable place for you to start.
    Thread at http://forums.parallax.com/showthread.php?t=118861
    Video at http://www.youtube.com/watch?v=PX0IhUqnwrk
    Article in Robot magazine May/June 2010. Code available at http://www.botmag.com/issue22/index.shtml
  • W9GFOW9GFO Posts: 4,010
    Parallax offers a Digital Encoder kit for the Boe-Bot.
    Be sure to look at Applying the Boe-Bot Digital Encoder Kit.
    Rich H
