DS1307+ / EEPROM sharing Pull-Up Resistors
MacTuxLin
Hello All,
Need an advice regarding RTC & EEPROM on the same SDA & SCL line. Each requires a 10k pull-up resistor to 3v3. Will there be any problem if I just implement 1 10k on each SDA & SCL line instead (picture)?
Thanks.
Thanks.
using two would be the same as using a single resistor with half the ohm value.
