Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
DS1307+ / EEPROM sharing Pull-Up Resistors — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
MacTuxLin
821
2010-09-23 10:29
edited 2010-09-23 18:42
in
Propeller 1
Hello All,
Need an advice regarding RTC & EEPROM on the same SDA & SCL line. Each requires a 10k pull-up resistor to 3v3. Will there be any problem if I just implement 1 10k on each SDA & SCL line instead (picture)?
Thanks.
1406 x 752
153K
153.1K
JonnyMac
9,843
2010-09-23 10:50
edited 2010-09-23 10:50
Yes, that's fine. Attached is a pic of a DS1307 in my Propeller Platform. You can see the shared pull-ups between the boot EEPROM and the DS1307.
640 x 480
459K
458.6K
tonyp12
1,951
2010-09-23 12:47
edited 2010-09-23 12:47
It's a bus, so only use one resistor to 3.3v.
using two would be the same as using a single resistor with half the ohm value.
MacTuxLin
821
2010-09-23 18:42
Thank you very much JonnyMac & Tonyyp12
Sign In
Register
to comment.
