Is there a way to change the name of a thread? — Parallax Forums
RavenkallenRavenkallen Posts: 1,057
edited 2010-09-24 13:26 in General Discussion
Well, i think the title pretty much sums it up. I could have sworn that some threads have different names then they did before...
    edited 2010-09-23 17:26
    Yes, there is. In your post, click on the edit button (obviously while logged in). That will give you the basic WYSWIG editing screen. Next to the save button is a "Go Advanced" button. Click on it and now you can edit the title, etc.
    edited 2010-09-23 17:27
  • RavenkallenRavenkallen Posts: 1,057
    edited 2010-09-23 17:45
    @WBAconsulting...I tried that and it just edits the name of the post and not the whole thread..
    @Phil...I find myself in a position similar to Humanoido. I want to update the subject so that people will know at a glance if anything important has happened..
    edited 2010-09-24 08:44
    Ravenkallen: Sorry, I should have mentioned that the title of the thread is the same as the title of the first post. So, if you edit the title of the first post (assuming it is your thread) it will effectively change the title of the thread. I just confirmed it's function on one of my testing threads.
    http://forums.parallax.com/showthread.php?t=125179
    edited 2010-09-24 11:50
    Huh, tried that to...Maybe i am doing it wrong. I go to edit post, then i go to go advanced, then i try to rename the first post and that works, but the thread name is the same...
    edited 2010-09-24 11:59
    No, you're not doing it wrong. WBA's moderator status enables the thread title change.
    Well, i guess you are going to have to make me a moderator, haha...Just kidding.
